some YouTube songs are playing others not
Hello
Today my Raspberry Pi 3 B, HiFiBerry AMP2 arrived :laughing: . So i quickly set it up with the last volumio version 2.348 and it worked out of the box.
I installed successful the youtube plugin.
But some youtube songs are played and others not. I get a notification that the specific song will start but it don’t starts.
Anyone facing this problem or it’s just me?
Is it bug? Or you guys have workaround?
gtz
After some debugging it looks like the YouTube plugin on volumio will only play the songs with the tag “Youtube Album: null Albumart” :confused:
See screenshot
I have a similar problem. Since 1 week no youtube-songs will start within the plugin. Was there some change from youtube site?
Please advice how the problem can be solved.
Thanks in advance
Raynold
same problem
I have the same problem, but I haven’t been able to play anything off of youtube. It started before I updated (last update had been around November 17) and was the reason I updated volumio.
Updated volumio to latest, uninstalled and reinstalled youtube plugin, and restarted with no change.
I checked, and all the songs I tried to play lack the album:null tag. I think joker5689 is on to something.
Further research showed the YouTube songs that playing have the tag “Album: null” and not “Youtube Album: null Albumart” as I mentioned earlier
They all have an albumart.
github.com/crisp00/PiYoutube
YouTube Playback for Volumio
Usage:
NOTE: This plugin is in development and the API will strongly change in the upcoming updates.
Hi vincent31,
The link you posted leads to the original plugin from Pintea.
Are you able to play all Youtube songs by installing that version instead of the one that is available in the Volumio store ?
I wonder.
  • Josef
Same here, broken after the last update
Hi all,
There are many different threads about that now.
It does not depend on the version you use.
Please post to this thread if you find something that may be helpful:
https://volumio.org/forum/youtube-for-volumio-t6608-70.html
The plugin author Pintea is already informed and we all hope he will find time soon to fix it - and that there is a solution at all.
Thank you all
  • Josef
Just for reference, these are youtube songs I have tried to play. None of them work. Edit: posted before I saw Josh2000’s post; if I find anything I will post it over there.
YouTube stopped working for me a little while ago. I tried uninstalling reinstalling and making sure all automatic updates were applied. Nothing.
I’ve reimaged my Pi3 with volumio 2.368 and tried installing the plugin (updated 18.2.18) again - nothing - no interface in browse - despite showing as being installed.
terrybooth,
You’ll probably get more of a response if you post over on this thread: youtube-for-volumio-t6608-70.html
The conversation has moved to over there.
