hi Guys
I have some questions about Volumio 2 lastest version.
I used Volumio on a RPi2 + Hifi Digi and the official 7 inch display.
The display and the touchscreen work as far as I think without any problems the plugin installed correctly.
But is it normally that under the plugins with the touch screen no settings are displayed? If I click on Settings, it shows me that there are no settings available.
Is that right? or something went wrong when installing.
My other question relates to the logging of logfiles.
I know that the Question has been asked many times before and that these are stored only temporarily in the memory to reduce the write access to the SD card. However, my logfiles on my other RPis are sent to my NAS via rsyslog and I want to implement this with Volumio.
By default, rsyslog is not installed, so I’m wondering if it is possible or even it is sense to install it without damaging the base system. or maybe it’s possible to redirect the logfiles via fstab instead of directly into a folder on my NAS?
Normally my NAS is set up by autofs on my RPis.
Could the line in the fstab be changed to get the log files instead of the temporary storage directly on my NAS? (If rsyslog is not a solution) and if so, would it be nice if someone could tell me what the fstab of Volumio would look like, so the log files will be loaded directly onto the NAS in the future.
Thanks and best regards
from Germany.
