[Solved] Volumio 2.348 for Pine64
I downloaded Volumio 2.348 for Pine64. However, No boot.
It is the correct image ?
I have the same issue. No boot with image 2.348.
hardware: pine64, 2GB with wifi
This will be checked this week, I have a little lack of time at the moment…
Thanks, I’m waiting for about 2.5 month.
Sorry that I missed the opening post, I located the problem and fixing it today.
Hope to publish a new image here today or tomorrow.
Edit:
This is your new image: pine64 v2.383
Just to make sure, I also updated sopine64 and pine64LTS: sopine64/pine64LTS v2.383
Thanks, Boot OK!
But I need to enable “Volume Normalization” with POT(SPDIF).
Yes, this is currently a known issue with pine64/ pine64LTS and sopine64 due to the available kernel/ I2S audio drivers.
There is nothing I can do at the moment.
I updated my pine64 = dead
I rewrote the sd card with 2.383 = dead
Are you sure it can boot with any pine64 ?
Hi balbuze,
you have to flash version 2.383. Updating from an older version will not work.
Updating is only supported from 2.383 onwards…
Yes, 2.383 works, I have tested it before releasing and it works here…
Cheers - Gé
Hi, I really have a problem to boot the volumio on my rock64. I almost try to use every version since it released.
I always connet find the internet light on, and I never find the IP address.
So, could you please let me know which version works on rock64? then I will try it.
