# \[Solved\] Volumio 1.5 MPDroid connection fails
**URL:** <https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793>\
**Category:** Help\
**Created:** [October 29, 2014, 12:56pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793 "2014-10-29T12:56:55Z")\
**Posts on this page:** 12\
**Page:** 1
<div class="post-metadata">
**Author:** ![Sadrak](https://community.volumio.com/letter_avatar_proxy/v4/letter/s/bb73d2/32.png) [@Sadrak](https://community.volumio.com/u/Sadrak)\
**Post date:** [October 29, 2014, 12:56pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/1 "2014-10-29T12:56:55Z")
</div>
After updating to 1.5 MPDroid app can not connect using the settings used for 1.41 (IP, port 6600, no password), what has
changed in this version?
**Author:** ![MobeyDuck](https://community.volumio.com/user_avatar/community.volumio.com/mobeyduck/32/25_2.png) [@MobeyDuck](https://community.volumio.com/u/MobeyDuck)\
**Post date:** [October 29, 2014, 1:24pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/2 "2014-10-29T13:24:57Z")
</div>
According to `
lsof -i
` mpd is listening on port 6600, so that should be correct.
Have you checked the IP, and made certain that volumio uses that IP?
**Author:** ![ICLlP](https://community.volumio.com/letter_avatar_proxy/v4/letter/i/8491ac/32.png) [@ICLlP](https://community.volumio.com/u/ICLlP)\
**Post date:** [October 29, 2014, 1:47pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/3 "2014-10-29T13:47:51Z")
</div>
> [@Sadrak](#):
I seem to have the same problem with MPaD for iOS.
**Author:** ![vittoriob](https://community.volumio.com/letter_avatar_proxy/v4/letter/v/ecb155/32.png) [@vittoriob](https://community.volumio.com/u/vittoriob)\
**Post date:** [October 30, 2014, 8:07am UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/4 "2014-10-30T08:07:36Z")
</div>
Same for me (Android).
No connections with Mpdroid.
Port is 6600 and IP is correctly set.
With or without password doesn’t work.
**Author:** ![souppunch](https://community.volumio.com/letter_avatar_proxy/v4/letter/s/9d8465/32.png) [@souppunch](https://community.volumio.com/u/souppunch)\
**Post date:** [October 30, 2014, 6:12pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/5 "2014-10-30T18:12:05Z")
</div>
This is due to an error in etc/mpd.conf
Directly after the flashing it contains an example config.
To change that you have to change some mpd settings via the GUI (menu/playback) and save it (you can revert it directly afterwards).
That will put an automatically generated content into mpd.conf and restart mpd. Afterwards it should listen to 6600 again.
**Author:** ![volumio](https://community.volumio.com/user_avatar/community.volumio.com/volumio/32/3_2.png) [@volumio](https://community.volumio.com/u/volumio)\
**Post date:** [October 30, 2014, 7:21pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/6 "2014-10-30T19:21:41Z")
</div>
That’s interesting… Didn’t spotted that… Ok so another thing to add on the to fix list
**Post date:** [October 31, 2014, 9:12am UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/7 "2014-10-31T09:12:37Z")
</div>
> [@souppunch](#):
It helped, now it works again, thanks!
**Post date:** [October 31, 2014, 3:58pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/8 "2014-10-31T15:58:55Z")
</div>
Sorry, what do you mean by “To change that you have to change some mpd settings via the GUI (menu/playback) and save it (you can revert it directly afterwards).” ?
Vittorio
**Post date:** [November 2, 2014, 9:30am UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/9 "2014-11-02T09:30:53Z")
</div>
This cannot be classed as “solved” until it has a better explanation of what to do.
**Author:** ![ning-yu](https://community.volumio.com/user_avatar/community.volumio.com/ning-yu/32/110_2.png) [@ning-yu](https://community.volumio.com/u/ning-yu)\
**Post date:** [November 2, 2014, 4:38pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/10 "2014-11-02T16:38:04Z")
</div>
> [@souppunch](#):
Sounds like you need to make a temporary change in the Menu-\>Playback settings and save it, This will create a proper mpd configuration file, which overwrites the example configuration file packaged with the release.
**Post date:** [November 2, 2014, 6:51pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/11 "2014-11-02T18:51:10Z")
</div>
> [@ning-yu](#):
Ok, got it.
I was looking some settings in MpDroid, instead the “Menu-\>Playback settings” are in Volumio.
Just made a Save Changes and now it’s working.
Vittorio
**Author:** ![andynz](https://community.volumio.com/user_avatar/community.volumio.com/andynz/32/30_2.png) [@andynz](https://community.volumio.com/u/andynz)\
**Post date:** [November 13, 2014, 8:35pm UTC](https://community.volumio.com/t/solved-volumio-1-5-mpdroid-connection-fails/1793/12 "2014-11-13T20:35:32Z")
</div>
I had the same problem. Fresh install of 1.5 and MPD control failed to connect. So I made a change to webui “menu” “playback” “audio output”, saved it and then changed the “audio output” back to normal for me (x20).
MPD control is now working ok.
