# \[SOLVED\] reset everything  SSH?
**URL:** <https://community.volumio.com/t/solved-reset-everything-ssh/6205>\
**Category:** Development talks\
**Created:** [June 12, 2017, 6:06pm UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205 "2017-06-12T18:06:27Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![jonas18z](https://community.volumio.com/user_avatar/community.volumio.com/jonas18z/32/113_2.png) [@jonas18z](https://community.volumio.com/u/jonas18z)\
**Post date:** [June 12, 2017, 6:06pm UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205/1 "2017-06-12T18:06:27Z")
</div>
Hi
Can I factoryreset, remove all plugins etc from SHH?
**Author:** ![volumio](https://community.volumio.com/user_avatar/community.volumio.com/volumio/32/3_2.png) [@volumio](https://community.volumio.com/u/volumio)\
**Post date:** [June 12, 2017, 7:36pm UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205/2 "2017-06-12T19:36:58Z")
</div>
sure
touch /boot/factory_reset
sync
reboot`
**Post date:** [June 13, 2017, 8:09pm UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205/3 "2017-06-13T20:09:22Z")
</div>
Perfect! Thanks. Saved many hours… when I install crashing plugins
**Post date:** [June 13, 2017, 11:00pm UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205/4 "2017-06-13T23:00:28Z")
</div>
Which plugin is crashing?
**Author:** ![speedturtle](https://community.volumio.com/user_avatar/community.volumio.com/speedturtle/32/807_2.png) [@speedturtle](https://community.volumio.com/u/speedturtle)\
**Post date:** [August 19, 2020, 6:06am UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205/5 "2020-08-19T06:06:20Z")
</div>
roon bridge. error connecting the host from China.
**Post date:** [August 26, 2020, 1:58pm UTC](https://community.volumio.com/t/solved-reset-everything-ssh/6205/6 "2020-08-26T13:58:05Z")
</div>
Or
`volumio updater userdata`
