[SOLVED] Music on internal hdd
Hello everyone,
i’m quite new to volumio.
I’m using it on a Lenovo X60 notebook.
I’ve installed it on the internal hdd, it’s a 250gb one, and i would like to know how to add the music library on the hdd itself. I’ve seen there are 3 partitions, the last one is 245 gb or so and it’s empty.
Thank you in advance and keep up the great work!
If it could be useful to other people:
  1. i’ve created a file in /boot/ called ssh
ctrl-alt-f4
user: volumio
pass: volumio
touch /boot/ssh
rebooted
connected to the ip via filezilla, and copied my music to /data/INTERNAL via network
Else it could be possible to copy files from an usb device, that is mounted iirc in /media/USB (or /mnt/USB, i don’t remember), then using cp -rfv source destination
