I’m having trouble installing volspotconnect2
I get the following issue:
Detecting cpu
Cpu is armv7l, downloading required package
Failed to download. Stopping installation now
The following error occurred when installing the plugin: Error
I think I have a raspberry pi2
I’ve installed it in the past without any issues.
an ideas why I can’t get it to work now?
You may well get a quicker reply if you address it directly to the Gihub site, but please post back here the resolution.
Thanks for the reply.
I saw a post about dns settings, so I played with that.
in the network i changed the dns to off, then my router, 192.168.0.1, then some google ones as seen here
github.com/balbuze/volumio-plugins/issues/40
I only changed in via the gui though.
even though it told me it had failed, its working now.
no idea what is going on, but its working
