Hello
Just downloaded volumio-2.031-2016-11-23-pi.img, copied on a rpi 3b and try to boot it.
kernel boot but hang on maintenance mode (please enter root password or ctrl+D to continue)
It seems that the root filesystem is not mounted properly (lot of files not exist)
is there a mistake on boot scripts on this image version resulting this error ?
md5 of my downloaded image is ok and same error on some new rpi and sd cards…
Thanks fot your help
