Yes I’m working for a fix. Just to explain, in a future version of Volumio (can’t tell you when though) a new layout will be used for the sound output. This new will make much more easy the plugin such as equalizer and make it more stable.
For the current, it is very hard to fix. I see that switching between sample rate or bitrate (track, radio) may result of no sound or frying sound. I try to find how to avoid it…
Thanks @balbuze, your answer enlightening.
Let me know if you want to test any configuration, at your command.
