Shutdown to stop pop/click with a MAX98357A DAC
Hi, new to Volumio 3.912 and have it running on a Pi 2W with DAC “Adafruit MAX98357” selected. I have a MAX98357A based DAC which pops/cracks loudly when first playing a song. Some reading elsewhere reveals this is likely down to the clocking being stopped then started and a solution is to use the Shutdown command to ensure the amp is enabled once the steam starts.
Google says I should add this to the boot/userconfig.txt file.
dtoverlay=max98357a,sdmode-pin=16
I have wired GPIO16 to the SD pin and the amp is constantly muted so assume the pin is pulled low.
Is there a better way to stop the pop?
If not, why is this method not working?
Thank you!
