I apologize for using volume in the car, is it possible to enable it to turn off as soon as I turn the key? obviously with a backup battery.
You need to provide better details, since when you turn youâre key off, it will already shutdownâŚ
I guess you mean something like tis:
https://juice4halt.com/
https://wiki.geekworm.com/X735
or google on safe shutdown raspberry when psu fails
if I turn the key it turns off I know, but not correctly, and the Micro SD is corrupted. I wanted to know if there is a system to turn it off correctly as soon as it senses that there is no more voltage, obviously with a battery or timed relay. with the translator I donât know if I can explain myself
itâs exactly what I need but it says that it is only tested by raspbian. I donât know if it works with volume
it think it will, both on the same kernel
