Should I turn it off?
I have been running Volumio very happily on a Raspberry Pi 400 for almost a year however the Pi has power issues (definitely the hardware). So today I decided to swap it out for a Lenovo Think centre TINY Pc I had knocking around. This has a 256gb SSD and 8 GB of ram. It’s working great but I am now thinking should I be shutting it down between sessions?? Any experience or advice?
it can run 24/7 if you don’t mind the electrical bill.
Thanks. Will leave on for now
The Pi has minimal moving parts, none if you don’t have a fan. A PC does have a fan which will get noisier as it ages, plus it will become less and less effective as it blows around a constant stream of house dust. Also, heat buildup in the CPU core itself will cause it to age prematurely. Turning the unit off after a session allows Volumio to do some house cleaning as well. Servers are built to run 24/7, consumer computers are not.
Thanks for the input…
Sorry to disagree, not all PC’s have fans.
Actually, there are some very budget priced, reasonably looking pc’s, very very suitable for Volumio.
PC’s originally planned as socalled “Thin Clients”.
Available on the 2nd hand market, as an example entry level Dell Wyse 3040 for around 40-60€, but the much better powered Dell Wyse 5070, not even much more expensive 80-100€, depending on configuration.
There are companies buying them as bulk from closing shops and resell. Just google a little.
Thanks for the comment. Yes the pc I am now using was bought very cheap second hand and I just added an SSD. It’s pretty small and quiet and one of the benefits I am finding is I have been able to copy lots of my library to the SSD and no longer need to run the external hard drive I have connected to the Pi.
I think this PC has a small fan and it runs very quietly.
