Shairport-sync from Windows with TuneBlade: no sound
Dear,
My system configuration:
  • Player: USBridge
  • Volumio: ver 2.348 for Sparky
  • Shairport-sync: Updated to 3.2RC5-OpenSSL-Avahi-ALSA-pa-soxr-metadata-sysconfdir:/etc
Symptoms:
  • Shair-Play from iOS: OK, all work well
  • Play from Windows with TuneBlade v1.7.3: NO SOUND although it shows connected and transfer rate between TuneBlade and Shairport-sync. Note that i can normally shair-play normally from my Windows 10 with TuneBlade to raspberry Pi3.
  • ShairPort-sync on USBridge (volumio) shows log when playing from TuneBlade on Windows 10:
    volumio@volumio:~$ Aliasing of buffer index – reset.
Does anyone have the same problem?
Thank very much and best regards,
