very thanks for answer
New image 3.569 with Tidal Flac, see post #1
Hi gkkpch, I used with success NEO3 with external DAC i i2S but no master clock input. Now I would like to do some experiments by sending the clock from the outside, I think this lowers the jitter terribly. I have potentially seen master clock solutions online even with two different frequencies. How do I understand what type of frequency I need to send for correct operation in PCM? could I send for example a 16.9344 and be sure it works? 48MHz? do I have to change the clock depending on the resolution of the songs? for example coming from TIDAL streaming? thank you for your time.
There is nothing I can do to help, as you can see from post #1, images are released as-is. I will probably skip my support for the neo3/neo2 board soon as since a few months there are images from @nikkov with full myvolumio support, which have excellent flexibility when it comes to i2s maste/slave options.With my version, it is fixed.
thanks for your time and for the fast responce to my questions.
3.611 versions available
See Opening Post
Hi friends… new 3.666 release? this have some problems with tidal…
what problem?
it should not be the case
Version 3.703 available to OTA updaters, direct download links:
Volumio-3.703-2024-06-08-nanopineo3
Volumio-3.703-2024-06-08-nanopineo2
Hi, can you help? I have tried your Nanopi Neo3 image using SPDIF it works, however, the Left and Right channels get swapped on every switch on, Have tried it on several DACs but the same result. I also have tried another Nanopi Neo3, but the same behaviour. I am very puzzled!
Tried to use Volumio-3.703-2024-06-08-nanopineo3 with SMSL n100 (based on NanoPi Neo3), but it couldn’t be loaded.
I’m sorry, the image is meant for a bare nanopi neo3, not for a possibly customized smsl OEM setup.
I’m afraid I can’t help, for support please contact your vendor instead.
I tried more times, and finally succeeded.
This one from nikkov branch has run:
https://updates.volumio.org/nanopineo3-armbian/volumio/3.703/Volumio-3.703-2024-06-09-nanopineo3-armbian.zip
After that I tried previous one noted in this branch - Volumio-3.703-2024-06-08-nanopineo3 - and it has run too.
Then I upgraded Volumio to the last version 3.832, and it seems to be mostly OK.
Qobuz connect works, but not seamlessly. Radio Paradise is OK, my own plugin too, but Radio 80s80s, MotherEarth Radio, Bandcamp not.
Was using USB DAC, not sure AES/EBU is working.
And Turn On/Off button of course does not affects. I’ll try to find corresponding GPIOs.
Hi Abagian,
Do you have Plug-Ins available on 3.832 on your N100?
Andy
Most plugins are available in non-official Volumio 3.832 I’ve installed. GPIO plugins are not compatible with NanoPi.
Official SMSL’s firmware has been also upgraded to 3.832, but plugins are still unavailable.
I’ve spend a lot of time trying to inject the plugins into original image or retrieve GPIO descriptions from there to force npn-official react to the button and LEDs but still has no success.
Currently I’m usging non-official. Waiting for the microSD card extender, going to make a slot in the bottom to have an ability to exchange these versions easy.
The blinking blue light is very annoying. I don’t care much about the on/off switch but the way that the non-official volumio for N100 degrade the user account down to non-premium is unacceptable. ![]()
Hi. WiFi work? Tidal Connect?
