Seeking help: Error with Raspberry Pi 4b & Touch Display 2 - much of the interface inoperable
Hello. I am a new user of the Volumio software and of the Pi/ Touchscreen environment. Could someone please advise on how to resolve the following problem in layman terms?
The Volumio Touch Display 2 interface attached to my Raspberry Pi 4b 8gb RAM is only partly working in that the Menu is active but none of the control buttons respondent. The system works fine on the remote web interface. My version of Volumio is 4.119.
When I installed the Touch Display 2 Plugin v3.6.0 using the web browser (Firefox) briefly got a red window with the error message that seemed like “unable to set brightness … EINVAL …”. It was too quick to disappear & I could not record it even though I was hovering on it. I then read various correspondence here & installed the beta version of the Plugin v3.5.7. Got the same error. A copy of the Live Log (I have no idea what the entries mean but can see there is a problem) is below and would greatly appreciate any advice that comes my way:
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
info: CoreCommandRouter::executeOnPlugin: system , getUpdaterChannel
info: CALLMETHOD: music_service inputs serialMonitorAction [object Object]
info: CoreCommandRouter::executeOnPlugin: inputs , serialMonitorAction
info: Error : CoreCommandRouter::executeOnPlugin: No method [serialMonitorAction] in plugin inputs
info: CALLMETHOD: system_controller motivocontrol displaySelection [object Object]
info: CoreCommandRouter::executeOnPlugin: motivocontrol , displaySelection
Starting setdatetime-helper.service - Time Synchronization Helper Service…
setdatetime-helper.service: Deactivated successfully.
Finished setdatetime-helper.service - Time Synchronization Helper Service.
Hey @kaz1984,
Welcome to our community.
Only right after supplying required details, anyone here can help. The choice is yours.
Tx for responding.
Yes I am seeking assistance & apologies for the wrong format of the request. Here is another try.
• I am having an issue with the Touch Screen interface on Volumio on a Raspberry Pi 4b. I can select only the Menu items but the other buttons on the screen related to play, pause etc seem not to respond. Everything works fine from the web interface.
• Raspberry Pi 4b, 8Gb RAM. 32Gb Sandisk Extreme SD card & Sandisk 64Gb USB
• Raspberry Pi Touch Display 2 - 7 inch
• Volumio Version 4.119,
• Touch Display Plugin: 3.6.0 (and also with 3.5.7 beta)
• Raspberry Pi USB C Power Supply
• No other hardware attachments either internally or externally to the Pi4b
• Unfortunately the link to how to send the log link from the device is a dead link. Additionally I uninstalled Volumio because of the issue but will install it again to provide the link if it is a definite requirement.
This however is a copy of what was in the log & I hope it provides some information:
• Currrently there is no additional hardware installed i.e. it is just the Raspberry Pi 4b and the Raspberry Pi Touch Display 2 as mentioned earlier.
I did go through the other links you posted to see if I could identify what I should do in my case but the technical detail was more than I could follow.
Is this information adequate & in the right format?
Hey @kaz1984,
Thank you, that is much closer to a proper report now, and much better. The device details are complete. The one thing still missing is the log link, and that one is a definite requirement. The pasted excerpt is only the live log tail and it does not contain the part we need (the plugin start-up and the brightness error you saw flash by).
The help page opens fine from here, so the link may have been mangled by your browser. Here are the steps written out so you do not need it:
  1. Boot the Pi with the Touch Display 2 attached and let the problem occur (open the touch screen, try the play/pause buttons).
  2. On another computer or phone on the same network, open a browser and go to one of these:
    • http://volumio.local/dev
    • http://<name-you-gave-the-player>.local/dev (if you renamed the player during setup, use that name instead of “volumio”)
    • http://<ip-address-of-the-pi>/dev (the IP is shown under Settings, then Network, in the web interface)
  3. On the DEV page, scroll down to the section called “Send logs or bug report”.
  4. In the text field, type a short description, for example: “Touch Display 2 buttons not responding, brightness EINVAL error”.
  5. Click “Send”.
  6. After a few seconds a link appears that starts with http://logs.volumio.org/ - use the copy button next to it and paste that link here in the thread.
That bundle contains the full system journal, so the error you could not catch on screen will be in there for us to read. Please do the whole thing in one go: reproduce first, then send the logs, so the failure is in the capture.
Once the link is here, we can look at what actually happened rather than guess.
Thank you for these excellent instructions which I have now carried out. The link is:
http://logs.volumio.org/volumio/LEa9RUq.html
I hope this is what is needed. If not, it is because I am not at all familiar with the technicalities of such systems but will happily try to comply.
Hey @kaz1984,
The log URL was the exact missing piece. You have two options:
  1. Complete setup for Pi4 as explained in this guide:
    [GUIDE] Official Raspberry Touch Display 2
  2. Or search in the Plugin store for Pi Screen Setup plugin, install and configure.
It has user friendly wizard, simply select your screen from drop-down menu, choose orientation and off you go.
Thank you yet again for this. I did the latter. Now the pi screen is live, in the correct orientation but just with the QR code showing. I can see it on the Volumio App and on my browser. Do I also need to install the plugin Touch Display in the User Interface section? Apologies for being a total dummy!
Hey @kaz1984,
The Touch Display plugin is meant to show Volumio UI on attached glass (HDMI/DSI/SPI). Volumio OS is a headless system, and aforementioned plugin is written for all users with directly connected screen.
Once more thank you! With your help & advice all is working well and this old man is happily listening on his headphones. Really grateful for your support.
