Satechi media button
Hello guys, I bought a satechi media button to use as remote control for volumio, but I have a problem on both platforms (Android and iOS). You explain my system, the scheme is as follows: raspberry with volumio controlled mainly through iPad with hotspot of my smartphone, but often not being able to bring the iPad drive me is uncomfortable use the app on Android not having support by car. So my idea was to connect the satechi iPad and use it as a normal remote control bt. Unfortunately, this does not happen in both systems. If you use YouTube can’t control it perfectly with satechi, but if I open volumio I can only raise and lower the volume, there is no way to use the other controls. I thought that the operation was the same YouTube. I hope someone can help me on this company
Inviato dal mio CLT-L09 utilizzando Tapatalk
