Samplerate problem on E-MU 0404USB
Hello!
I see problem with it. When playing files like 24/96, 16/48, somtheng another than 16/44,1 sound bitstreaming in soundcard, but operating system doesnt cachge internal clock of it quartz, so 0404usb decoding at 44100 samples all files and cause quality.
People, may anybody help me? I dont know how explain my problem right. Dont work clock selector for emu 0404usb. WHo have same audiocard, please check that problem/ Volumio 1.51, downsampling is off. Soundcard always playing at 44100hz, but rpi say that stream is another params, at 100% software problem, but i dont know how its fix(((
What about this solution change-the-default-alsa-sample-rate-44100-t81.html
It seems to solve as for my 0202usb.
You can change the samplerate manually with the alsamixer command using SSH.
This allows me to use my 0404 USB without resampling, you need to change the ‘Clock rate Selector’ slider.
However I haven’t figured out the samplerate with volumio just yet, I’m pretty new and still learning the ropes.
Here is the solution for E-MU USB 0404:
guid-for-customize-volumio-image-t11628.html#p60036
