rpi3, hifiberryplus dac, volumio 2.348 no sound
rpi3, hifiberryplus dac,volumio software2.43.
Have tried switch l2c off saved restarted multiple times still no sound. Have spent several weeks trying different software rasp full, rasp lite. Still no sound
Any insight gratefully accepted. Results of aplay -l and boot/config.txt listed below.
TIA
daily
aplay -l results
volumio@volumio:~$ aplay -l
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Hi Fi pcm512x-hifi-0 []
Subdevices: 0/1
/boot/config.txt
initramfs volumio.initrd
gpu_mem=16
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1s
ssh
Volumio i2s setting below: do not alter
dtoverlay=hifiberry-dacplus
So, with a HFB DAC+, you should have something like the attached image. Then you should have a couple of RCA connections out to a line-level input on an amp or active speaker of some kind. When music is playing through the DAC+, you should have agreen LED alight in the middle of the HFB card; do you have that?
Chris M
