RPI3 B+ ethernet problem (crackles/lost packets)
Hi everyone,
a super fast and simple question: the problems described by Michelangelo in the BLOG
(volumio.org/raspberry-pi-3-b-plus-audio-review/) have been solved?
I would love to buy the new RPI3 B+ and obviously use it with Volumio :slight_smile:
Many thanks,
Michele
Really anybody knows? :frowning:
Thanks, Michele
Archimago reported the same issue in a blog post today - he was using piCorePlayer.
archimago.blogspot.com/2018/09/u … eamer.html
Apparently there is an extension in piCorePlayer that fixes the issue, and Volumio would need the same fix.
In fact newer kernels (the ones that we use in volumio) did solve the issue and the last time I tried it was working perfectly also via Ethernet without crackles.
Many thanks Michelangelo, great news here! If you have 5 mins please update the blog
so everyone knows that now it’s ok and do not get scared with that bad news.
PS: thanks to skikirkwood for the info about Archimago
Sooo…Rpi3 B+ will come soon :smiley:
As always, thanks again for your great work :slight_smile:
