@nerd
Strange thing I see is when I run cat /var/log/Xorg.0.log
[ 64.349] (II) modeset(0): Output DSI-2 using monitor section DSI-2
[ 64.349] (**) modeset(0): Option "Rotate" "normal"
[ 64.349] (II) modeset(0): EDID for output DSI-2
[ 64.349] (II) modeset(0): Printing probed modes for output DSI-2
[ 64.349] (II) modeset(0): Modeline "800x480"x60.0 27.78 800 859 861 907 480 487 489 510 -hsync -vsync (30.6 kHz eP)
[ 64.349] (II) modeset(0): Output DSI-2 connected
[ 64.349] (II) modeset(0): Using exact sizes for initial modes
[ 64.349] (II) modeset(0): Output DSI-2 using initial mode 800x480 +0+0
[ 64.349] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 64.349] (==) modeset(0): DPI set to (96, 96)
Full output:
volumio@rpi5:~$ cat /var/log/Xorg.0.log
[ 63.851]
X.Org X Server 1.20.4
[ 63.851] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 63.851] Current Operating System: Linux rpi5 6.1.69-v8+ #1710 SMP PREEMPT Thu Dec 21 13:21:40 GMT 2023 aarch64
[ 63.851] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:BD:67:B4 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA10,115200 console=tty1 imgpart=UUID=0c3a77ec-ae84-4f1b-8028-c61cc251ffe5 imgfile=/volumio_current.sqsh bootpart=UUID=41CA-9A8B datapart=UUID=0324d53a-d066-482b-b659-eb98af2b49e7 uuidconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=7 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 nodebug use_kmsg=no
[ 63.851] Build Date: 04 April 2023 07:50:56AM
[ 63.851] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 63.851] Current version of pixman: 0.36.0
[ 63.851] Before reporting problems, check http://wiki.x.org
[ 63.851] Markers: (--) probed, (**) from config file, (==) default setting,
[ 63.851] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Sep 8 20:05:50 2024
[ 63.853] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 63.853] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 63.855] (==) No Layout section. Using the first Screen section.
[ 63.855] (==) No screen section available. Using defaults.
[ 63.855] (**) |-->Screen "Default Screen Section" (0)
[ 63.855] (**) | |-->Monitor "<default monitor>"
[ 63.857] (==) No monitor specified for screen "Default Screen Section".
[ 63.857] (==) Automatically adding devices
[ 63.857] (==) Automatically enabling devices
[ 63.857] (==) Automatically adding GPU devices
[ 63.859] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 63.862] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 63.862] Entry deleted from font path.
[ 63.866] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 63.866] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 63.866] (II) The server relies on udev to provide the list of input devices.
[ 63.866] (II) Loader magic: 0x1fdf80
[ 63.866] (II) Module ABI versions:
[ 63.866] X.Org ANSI C Emulation: 0.4
[ 63.866] X.Org Video Driver: 24.0
[ 63.866] X.Org XInput driver : 24.1
[ 63.866] X.Org Server Extension : 10.0
[ 63.866] (--) using VT number 2
[ 63.866] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 63.868] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 63.868] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 63.868] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 63.869] (II) no primary bus or device found
[ 63.869] falling back to /sys/devices/platform/axi/1000120000.pcie/1f00130000.dsi/drm/card0
[ 63.869] (II) LoadModule: "glx"
[ 63.869] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 63.881] (II) Module glx: vendor="X.Org Foundation"
[ 63.881] compiled for 1.20.4, module version = 1.0.0
[ 63.881] ABI class: X.Org Server Extension, version 10.0
[ 63.881] (==) Matched modesetting as autoconfigured driver 0
[ 63.881] (==) Matched fbdev as autoconfigured driver 1
[ 63.881] (==) Assigned the driver to the xf86ConfigLayout
[ 63.881] (II) LoadModule: "modesetting"
[ 63.882] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 63.883] (II) Module modesetting: vendor="X.Org Foundation"
[ 63.883] compiled for 1.20.4, module version = 1.20.4
[ 63.883] Module class: X.Org Video Driver
[ 63.883] ABI class: X.Org Video Driver, version 24.0
[ 63.883] (II) LoadModule: "fbdev"
[ 63.884] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 63.884] (II) Module fbdev: vendor="X.Org Foundation"
[ 63.884] compiled for 1.20.3, module version = 0.5.0
[ 63.884] Module class: X.Org Video Driver
[ 63.884] ABI class: X.Org Video Driver, version 24.0
[ 63.884] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 63.884] (II) FBDEV: driver for framebuffer: fbdev
[ 63.903] (II) modeset(0): using drv /dev/dri/card0
[ 63.903] (WW) Falling back to old probe method for fbdev
[ 63.903] (II) Loading sub module "fbdevhw"
[ 63.903] (II) LoadModule: "fbdevhw"
[ 63.904] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 63.907] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 63.907] compiled for 1.20.4, module version = 0.0.2
[ 63.907] ABI class: X.Org Video Driver, version 24.0
[ 63.907] (II) modeset(G0): using drv /dev/dri/card2
[ 63.907] (II) modeset(0): Creating default Display subsection in Screen section
[ 63.907] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 63.907] (==) modeset(0): RGB weight 888
[ 63.907] (==) modeset(0): Default visual is TrueColor
[ 63.907] (II) Loading sub module "glamoregl"
[ 63.907] (II) LoadModule: "glamoregl"
[ 63.907] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 63.924] (II) Module glamoregl: vendor="X.Org Foundation"
[ 63.924] compiled for 1.20.4, module version = 1.0.1
[ 63.924] ABI class: X.Org ANSI C Emulation, version 0.4
[ 64.348] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 64.349] (EE) modeset(0): glamor initialization failed
[ 64.349] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 64.349] (II) Loading sub module "fb"
[ 64.349] (II) LoadModule: "fb"
[ 64.349] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 64.351] (II) Module fb: vendor="X.Org Foundation"
[ 64.351] compiled for 1.20.4, module version = 1.0.0
[ 64.351] ABI class: X.Org ANSI C Emulation, version 0.4
[ 64.351] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 64.351] (==) modeset(G0): RGB weight 888
[ 64.351] (==) modeset(G0): Default visual is TrueColor
[ 64.351] (II) Loading sub module "glamoregl"
[ 64.352] (II) LoadModule: "glamoregl"
[ 64.352] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 64.352] (II) Module glamoregl: vendor="X.Org Foundation"
[ 64.352] compiled for 1.20.4, module version = 1.0.1
[ 64.352] ABI class: X.Org ANSI C Emulation, version 0.4
[ 64.706] (II) modeset(G0): Refusing to try glamor on llvmpipe
[ 64.707] (EE) modeset(G0): glamor initialization failed
[ 64.707] (II) modeset(G0): ShadowFB: preferred NO, enabled NO
[ 64.710] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 64.712] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 64.715] (II) modeset(G0): EDID for output HDMI-1-1
[ 64.717] (II) modeset(G0): EDID for output HDMI-1-2
[ 64.717] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 64.717] (==) modeset(G0): DPI set to (96, 96)
[ 64.717] (II) Loading sub module "fb"
[ 64.717] (II) LoadModule: "fb"
[ 64.717] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 64.717] (II) Module fb: vendor="X.Org Foundation"
[ 64.717] compiled for 1.20.4, module version = 1.0.0
[ 64.717] ABI class: X.Org ANSI C Emulation, version 0.4
[ 64.717] (II) UnloadModule: "fbdev"
[ 64.717] (II) Unloading fbdev
[ 64.717] (II) UnloadSubModule: "fbdevhw"
[ 64.717] (II) Unloading fbdevhw
[ 64.725] (==) modeset(G0): Backing store enabled
[ 64.725] (==) modeset(G0): Silken mouse enabled
[ 64.728] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 64.728] (==) modeset(G0): DPMS enabled
[ 64.729] (==) modeset(0): Backing store enabled
[ 64.729] (==) modeset(0): Silken mouse enabled
[ 64.736] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 64.736] (==) modeset(0): DPMS enabled
[ 64.736] (II) Initializing extension Generic Event Extension
[ 64.737] (II) Initializing extension SHAPE
[ 64.737] (II) Initializing extension MIT-SHM
[ 64.737] (II) Initializing extension XInputExtension
[ 64.741] (II) Initializing extension XTEST
[ 64.741] (II) Initializing extension BIG-REQUESTS
[ 64.741] (II) Initializing extension SYNC
[ 64.742] (II) Initializing extension XKEYBOARD
[ 64.742] (II) Initializing extension XC-MISC
[ 64.743] (II) Initializing extension SECURITY
[ 64.743] (II) Initializing extension XFIXES
[ 64.743] (II) Initializing extension RENDER
[ 64.744] (II) Initializing extension RANDR
[ 64.744] (II) Initializing extension COMPOSITE
[ 64.745] (II) Initializing extension DAMAGE
[ 64.745] (II) Initializing extension MIT-SCREEN-SAVER
[ 64.745] (II) Initializing extension DOUBLE-BUFFER
[ 64.746] (II) Initializing extension RECORD
[ 64.746] (II) Initializing extension DPMS
[ 64.746] (II) Initializing extension Present
[ 64.747] (II) Initializing extension DRI3
[ 64.747] (II) Initializing extension X-Resource
[ 64.747] (II) Initializing extension XVideo
[ 64.747] (II) Initializing extension XVideo-MotionCompensation
[ 64.747] (II) Initializing extension SELinux
[ 64.747] (II) SELinux: Disabled on system
[ 64.747] (II) Initializing extension GLX
[ 64.748] (II) AIGLX: Screen 0 is not DRI2 capable
[ 64.799] (II) IGLX: Loaded and initialized swrast
[ 64.799] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 64.799] (II) Initializing extension XFree86-VidModeExtension
[ 64.799] (II) Initializing extension XFree86-DGA
[ 64.799] (II) Initializing extension XFree86-DRI
[ 64.802] (II) Initializing extension DRI2
[ 64.803] (II) modeset(G0): Damage tracking initialized
[ 64.803] (II) modeset(0): Damage tracking initialized
[ 64.803] (II) modeset(0): Setting screen physical size to 211 x 127
[ 64.886] (II) config/udev: Adding input device pwr_button (/dev/input/event0)
[ 64.886] (**) pwr_button: Applying InputClass "libinput keyboard catchall"
[ 64.886] (II) LoadModule: "libinput"
[ 64.887] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 64.900] (II) Module libinput: vendor="X.Org Foundation"
[ 64.900] compiled for 1.20.3, module version = 0.28.2
[ 64.900] Module class: X.Org XInput Driver
[ 64.900] ABI class: X.Org XInput driver, version 24.1
[ 64.900] (II) Using input driver 'libinput' for 'pwr_button'
[ 64.900] (**) pwr_button: always reports core events
[ 64.900] (**) Option "Device" "/dev/input/event0"
[ 64.900] (**) Option "_source" "server/udev"
[ 64.912] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 64.912] (II) event0 - pwr_button: device is a keyboard
[ 64.912] (II) event0 - pwr_button: device removed
[ 64.932] (**) Option "config_info" "udev:/sys/devices/platform/pwr_button/input/input0/event0"
[ 64.932] (II) XINPUT: Adding extended input device "pwr_button" (type: KEYBOARD, id 6)
[ 64.932] (**) Option "xkb_model" "pc105"
[ 64.932] (**) Option "xkb_layout" "us"
[ 64.933] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 64.933] (II) event0 - pwr_button: device is a keyboard
[ 64.934] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event1)
[ 64.934] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 64.934] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 64.934] (**) vc4-hdmi-0: always reports core events
[ 64.934] (**) Option "Device" "/dev/input/event1"
[ 64.934] (**) Option "_source" "server/udev"
[ 64.935] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 64.935] (II) event1 - vc4-hdmi-0: device is a pointer
[ 64.935] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 64.936] (II) event1 - vc4-hdmi-0: device removed
[ 64.964] (II) libinput: vc4-hdmi-0: needs a virtual subdevice
[ 64.964] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 64.964] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: MOUSE, id 7)
[ 64.964] (**) Option "AccelerationScheme" "none"
[ 64.964] (**) vc4-hdmi-0: (accel) selected scheme none/0
[ 64.964] (**) vc4-hdmi-0: (accel) acceleration factor: 2.000
[ 64.964] (**) vc4-hdmi-0: (accel) acceleration threshold: 4
[ 64.965] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 64.966] (II) event1 - vc4-hdmi-0: device is a pointer
[ 64.966] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 64.967] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event2)
[ 64.967] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 64.967] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 64.967] (**) vc4-hdmi-1: always reports core events
[ 64.967] (**) Option "Device" "/dev/input/event2"
[ 64.967] (**) Option "_source" "server/udev"
[ 64.968] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 64.969] (II) event2 - vc4-hdmi-1: device is a pointer
[ 64.969] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 64.969] (II) event2 - vc4-hdmi-1: device removed
[ 64.988] (II) libinput: vc4-hdmi-1: needs a virtual subdevice
[ 64.988] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 64.988] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: MOUSE, id 8)
[ 64.988] (**) Option "AccelerationScheme" "none"
[ 64.988] (**) vc4-hdmi-1: (accel) selected scheme none/0
[ 64.988] (**) vc4-hdmi-1: (accel) acceleration factor: 2.000
[ 64.988] (**) vc4-hdmi-1: (accel) acceleration threshold: 4
[ 64.989] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 64.990] (II) event2 - vc4-hdmi-1: device is a pointer
[ 64.990] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 65.003] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 65.003] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 65.003] (**) vc4-hdmi-0: always reports core events
[ 65.003] (**) Option "Device" "/dev/input/event1"
[ 65.003] (**) Option "_source" "_driver/libinput"
[ 65.003] (II) libinput: vc4-hdmi-0: is a virtual subdevice
[ 65.003] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 65.003] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: KEYBOARD, id 9)
[ 65.003] (**) Option "xkb_model" "pc105"
[ 65.003] (**) Option "xkb_layout" "us"
[ 65.003] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 65.003] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 65.003] (**) vc4-hdmi-1: always reports core events
[ 65.003] (**) Option "Device" "/dev/input/event2"
[ 65.003] (II) libinput: vc4-hdmi-1: is a virtual subdevice
[ 65.004] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 65.004] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: KEYBOARD, id 10)
[ 65.004] (**) Option "xkb_model" "pc105"
[ 65.004] (**) Option "xkb_layout" "us"
[ 67.856] (II) modeset(0): Disabling kernel dirty updates, not required.
volumio@rpi5:~$ xrandr --display :0 --query
Screen 0: minimum 320 x 200, current 800 x 480, maximum 4096 x 4096
DSI-2 connected primary 800x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
800x480 60.05*+
