The plug in for Rotary encoders is not working. I have tried every rendition and pin combination I can think of; I have uninstalled and reinstalled; the encoders do not work. Can you folks check the plugin and ensure it is operational? I am using a RPi 2 B with the 1/12 rendition of Volumio and ADAfruit rotary encoders. The encoders work on other projects. It appears the newest rendition of Volumio has changed something causing the encoder plugin to no longer operate. Any help would be appreciated as this project is essentially on hold until I can get the encoder issue addressed.
I found it didn’t work too, it’s the plug-in code rather than the encoder itself. I ended up writing a bit of Python code to do it and it works well. I’ve posted about it here so have a look.
Would love to see the code; however, there was no link included in your message.
Have a look on this thread…
guide-for-setting-touchscreen-backlight-control-t11425-10.html
