I absolutely hate this Rivo+ device, it will not find my network. I have tried resetting Rivo+. Resetting network. Ethernet, Wifi, App. You name it.
Does anyone have a fix for this piece?
As a Volumio device owner you can open a service ticket.
Here on the community forum, there is a process to ask help from the fellow users/volunteers.
https://community.volumio.com/t/tips-and-guidelines-to-get-faster-help
Hi @Tedroy, sorry for the frustration, let’s get your Rivo+ working. Please try this, in this exact order:
If it still doesn’t show up, please let us know
If it still doesn’t show up, please contact our support team directly at Support chat: Volumio, so we can look at your device with you.
Hat die von Marco vorgeschlagene Reihenfolge inzwischen etwas verändert? Besonders hilfreich wäre die Rückmeldung, ob der Rivo+ im Router eine IP-Adresse bekommt und darüber erreichbar ist, auch wenn die App ihn nicht findet. Dann wäre klarer, an welcher Stelle die Verbindung scheitert.
Please use English on the forum. There are plenty free tools to translate.
Don’t expect that community members do the trranslation for you.
I can connect it now it’s loosing connection every 5 mins or so. Wired connection and wireless
Sorry to hear that! This is not the kind of experience you should be getting.
Can you get in touch trough our support channels? A specialist will take it from there. This way, we can get some diagnostics that will help us pinpoint the issue and effectively solve them
I tried going through the support channel. I just got an unhelpful Ai response pointing me back to here.
Hey @Tedroy,
Sorry you ended up going round in circles. Let’s try to narrow it down here.
The Rivo+ runs fine on an ordinary home network, as long as that network lets devices find and talk to each other directly. The Volumio app finds the Rivo+ using mDNS (Bonjour), which relies on multicast traffic, and some router and mesh settings get in the way of that. So, a few checks first, starting with the one that tells us the most.
Same network
Your phone must be on the same network as the Rivo+, not a guest WiFi. If you use an extender, a mesh system or a second router, it must run in access point (bridge) mode, not as a router of its own. Otherwise the phone ends up on a different subnet and the app cannot see the Rivo+.
Client isolation
Look in your router’s WiFi settings for “AP isolation”, “client isolation” or similar. It must be off for the network your phone uses.
Multicast settings
Some routers have an option such as “Multicast to Unicast” in their advanced WiFi settings. One user here cured app discovery problems by switching it off. Mesh systems and power-saving modes can also interfere with multicast.
Your phone
Wired vs wireless
While the Ethernet cable is plugged in, the Rivo+ uses the cable and WiFi does not connect, by design. For the wireless test, physically unplug the cable.
Optional: fixed address
Reserve the Rivo+ IP address in your router (DHCP reservation), so that http://<rivo_ip> always works as a fallback.
If all of the above checks out and it still drops, please post:
