Hi All - Mark newbie here from sunny Sunderland.
I have a problem with my Rivo Plus reversing channels when sending via i2s to a PS audio Directstream DAC. The DAC has another i2s input, which I use with a CD transport with no problem. The Rivo Plus is set to PS Audio, and is up to date with firmware. I stream via Qobuz Connect, and have tried other HDMI cables with no luck.
Obviously I can reverse the output connections from the DAC to my amp, but then would have to swap again if I needed to listen to CD, which is a pain.
Any help greatly appreciated!
