Rivo no longer detects USB DAC (Pathos HiDac2) – only S/PDIF available in Output Device
Hardware: Volumio Rivo, wired Ethernet, fixed IP
Volumio version: 4321
DAC: Pathos Classic Remix with HiDac2 module, connected via USB
Log: Hardware: Volumio Rivo, wired Ethernet, fixed IP
Volumio version: [x.xxx]
Log: http://logs.volumio.org/rivo/87sg5Yy.html
Since 30 October the Rivo no longer sees my USB DAC. In Playback Options → Output Device the dropdown only offers S/PDIF; the HiDac2 is gone. Playing anything from the Volumio UI gives the error “cannot stream to selected output device”. Qobuz Connect connects and the track progresses, but there is no sound (same cause, I assume).
What I have ruled out so far:
  • The DAC works: connected to a laptop over USB it shows up immediately as a USB audio device.
  • Two different USB cables tested (original Ricable Dedalus and a standard USB-A/B cable).
  • Tried all USB ports on the Rivo.
  • Rivo fully power-cycled (unplugged 30 s), DAC fully power-cycled, DAC powered on and set to USB input before the Rivo boots.
  • Output device re-selected and saved, mixer type set to None.
  • Shairport disabled.
Everything worked fine until 30 October; no settings were changed. Is this a known issue, and what would you suggest next? I’d rather not do a factory reset without knowing whether it addresses this.
Thanks in advance.
Hi @Pytrik, thank you for the detailed report and the log. I’ve checked it with our team: this isn’t a settings issue, and a factory reset wouldn’t help, so you did the right thing not to do it. Let’s continue privately so we can sort out the repair: please contact us at Support chat: Volumio , mentioning this thread issue and your Rivo’s date of purchase, and we’ll take it from there. In the meantime, you can keep using the Rivo via S/PDIF.
GDSC-5794
I wrote to you on 23.10.2026, since then there has been no reaction from your side. I can’t get into Volumio’s help; they’ve changed something because logging in to Jira doesn’t work for me.
It would be nice to reply to my email once.
Greetings from Lazic
Dear Mr. Lazic,
First of all, I’m very sorry for the silence since your last message on 23 October. Unfortunately we recently changed the tool we use to manage support requests, and during the switch your conversation was left behind, which is also why the login to our previous help portal no longer works for you. To avoid any further delay, we’ll continue this conversation here by email.
Thank you for all the tests you did, and for sending your purchase documents. Based on your logs and on what you found (no USB device detected on any port, while the microSD slot, AES and coaxial outputs work), our hardware team has confirmed that the USB hub inside your Rivo’s main board is no longer responding. This is a hardware fault, so no setting or factory reset can fix it.
Since your Rivo was purchased in January 2024, it is no longer covered by the warranty. However, we can repair it for you as a paid service. If you’d like to proceed, just let us know, and we’ll send you a proforma invoice with the repair cost and the shipping, together with the instructions to send us the unit.
In the meantime, you can keep using the Rivo through its AES and coaxial outputs, as well as your Rivo Plus.
Best regards,
Marco
So, this means that I have a hardware issue like mr. Lazic, and you can repair it as a paid service?
Best regards,
Pytrik
Hi @Pytrik, thanks, I’ve seen your message in our support chat and I’ve just replied to you there, please check the chat or your email. For privacy reasons I can’t discuss other users’ cases here.
