**UPDATE: I appear to have solved the issue by swapping to a different USB slot on my RPi! Strange because it played CDs just fine, but I understand there could be a power issue. Would a log be able to tell me?
Equipment: RPi 4, 8GB RAM
Generic external Optical Drive
Software version: Volumio v4.119, Manifest UI, Premium account
Hi all,
I’m another person in the “can’t rip CD” category. I did some searching here and switched my optical drive to a high powered hub to see if that solved the problem.
However I’m still running into the same issue. I’ve tried hitting the rip button on the Audio CD screen via the app and 2 different browsers on two different laptops. The “rip CD” button just doesn’t seem to respond and presents no errors in the UI.
One other item to note: the system doesn’t seem to be able to find the metadata for the CD I’m trying to rip, despite it being an official release (release AACD 099 on Analog Africa). Could that be my issue?
Is there any kind of log I can access within Volumio to see if there’s some kind of error happening in the background? Anything else I should check?
Thanks in advance!
-carlos
