Restrict WebUI access?
My current setup is a Pi2B (with Allo Boss DAC) running the latest version of Volume (2.526). I have connected a WiFi USB adapter (TL-WN725N v3) which is used to create a hotspot. The ethernet port is also used to connect to the content and is connected to a different network. The hotspot functionality is working nicely and allows me to connect to the webUI.
I would like to use the hotspot network to control the WebUI and use the ethernet connection for content only (and ssh access). Right now the WebUI can accessed from both networks. I would like to restrict access to the WebUI via the ethernet network. I was hoping to do that by editing the web server configuration file, but that doesn’t seem easy (or I’ve missed it entirely).
Is there a way to do this? Maybe by modifying iptables?
