Restart on its own
2.452 Version My Volumio Hifibery DAC Pro 10 x restarting for no reason on its own this morning- Freaking?
Are you having power supply problems , possibly? I know… but don’t have an idea what else to suggest if your device has been working previously.
No its a 2 A 5 Volt…
But the mains supply to your house has been steady? I ask because where I live we get occasional mini power cuts, where the power goes off for a very short period of time, and may happen several times over a couple of hours.
Power rock sold has somting do w Ethernet or Handy Bluetooht stray signal. Tody no more occuring
The most stable solution is to solder the 5V supply to the GPIO pins and not power them via USB.
The USB plugs and sockets are sometimes very bad and have a high voltage drop. Just like the cheap jumper cables.
On my Hifiberry DIGI Pro+ I use 3.3 LIFEPO for Dac & 5 Volt Lipo 17000mA for The Berry @ USB soldered
On my DAC plus LIPO 17000mA have to solder Plug for direct power on the board
Batterie Power with 15 x 470 uf Rubicon Z parallel and 1 o2 two 10 uf RIFA Polpropylen sounds much better in my opinion
It so coming again. SMS Smartphone makes Volumio to Restart. On my Mac OS 10.13.6 repalce finder window Volumio Restart. SPOOKY
Could be a ground Problem have later to do earthing the Router.Or turning the 220 Volt USN`B Plug the other way around. It as a Raspy Problem = Electronic Stray Signals comming in. Right now use big LIPO 17000 mA USP Power for the Raspy…
It was the Bluetooht connection switching OFF Problem solved…
