I am a happy owner of the Volumio Primo Plus, which I use exclusively as a Roon Ready endpoint, connected via RCA to an integrated tube amplifier with its own analogue volume control.
In Roon, I have configured the Primo Plus to use Fixed Volume, with all DSP processing disabled. The signal path in Roon shows Lossless.
However, I have noticed that the physical volume knob on the Primo Plus remains active during Roon Ready playback, even when Fixed Volume is selected in Roon.
This raises a few technical questions:
When Roon is configured to Fixed Volume, does the Primo Plus still apply its internal volume control to the audio signal?
If I set the Primo Plus volume to 100%, does this correspond to 0 dB attenuation, ensuring bit-perfect playback?
Is the volume control implemented digitally within the ESS DAC, or through a separate analogue volume stage?
Is there a way to completely bypass the Primo Plus volume control when using Roon Ready, effectively turning it into a fixed-output DAC?
For reference, I have configured the DAC Output Level to 0.775 Vrms.
My goal is simply to achieve the cleanest possible signal path, leaving all volume adjustments to my integrated amplifier.
I would appreciate any technical clarification from the Volumio team.
on primo Plus the audio stream is always sent to the DAC at full-scale, with no manipulation at all (bit-perfect), regardless the selected volume value.
the volume acts on the I2C register of the ES9039Q2M, that will adjust the output level accordingly, without manipulating the incoming bit-stream: it acts on the gain of the output stage.
In fact, you can have volume control working even with DSD (on the USB input DSD direct and DoP are supported), this would not be possible with a software-like approach, because it’s not possible to attenuate a DSD audio stream without converting it to PCM first. it works with DSD too because the gain on the output stage is affected by the register setting related to the volume.
The volume control on the Primo Plus is done in hardware, but inside the DAC itself and not with an external circuit.
if you keep the volume at 100 and you don’t touch it, the device will behave as a fixed-output DAC. but even if you use the volume control, it will still be bit-perfect.
Afaik, the ESS chips convert DSD to their own proprietary internal low-bit PCM-like format and after this are processed just like PCM input would be, so volume can be controllable even with DSP after this conversion stage and, indeed, this is what happens. I stand to be corrected if I’m wrong.
Having said this, this is the first time I read that the ESS chips provide what you describe as effectively hardware analog output stage gain control. I’ve always thought their volume control is strictly 32-bit digital DSP, is performed before the D-to-A conversion, thus before the output stage and, as such, volume control is indeed what you describe as ‘software-like’ though hardware implemented. It is digital processing performed in hardware by the DAC chip. In principle this is no different than software volume control in terms of its functionality. The only way to provide analog (and not DSP) volume control is to provide an attenuation or gain control method external to the chip in the I/V stage. Again, I stand to be corrected if I’m misinformed.
