Raspdac 0.0.3 on Volumio 3.444
Hi, I can not install the Raspdac 0.0.3 plugin on a fresh version of Volumio 3.444 card. The installation is successful (ssh + wget etc…), but the plugin is not activated in UI plugin section of Volume menu. I received an alarm and does not activate. Is there a reason? I have an Audiophonic DAC I2R on Rasp with a PWR button and OLED 16x2. This plugin could be very helpful. Can someone help me?
Last part of Log of the intallation:
This command will install the plugin on your device
Compressing the plugin
Plugin succesfully compressed
Progress: 10
Status :smiley:ownloading plugin
Progress: 30
Status :Creating folder on disk
Progress: 40
Status :Unpacking plugin
Progress: 50
Status :Checking for duplicate plugin
Progress: 60
Status :Copying Plugin into location
Progress: 70
Status :Installing dependencies
Progress: 70
Progress: 90
Status :Adding plugin to registry
Progress: 100
Status :stuck_out_tongue:lugin Successfully Installed
Done!
volumio@volumio:~/audiophonicsonoff-plugin$ reboot
