Raspberry PI3, Hifiberry Digi+ Pro, General Playback options
Hello, I’m new to Volumio but I’m definitly in love with it!!!
My gear is a Raspberry PI3 + Hifiberry Digi+ Pro (I use an external Teac DAC) and I have few little (an possible simple) questions about right configuration.
Audio output (in General Playback options)
I found two possibile way to configure it and both works but, wich one is better?
#01
“output device -> snd_rpi_hifiberry_digi”
“I2S DAC -> Off”
#02
"output device -> HiFiBerry Digi+ Pro "
“I2S DAC -> ON”
“DAC model - > HiFiBerry Digi+ Pro”
Volume Options
I have only two possibile choices about “Mixer type”:
  • None (ok!, I use the amplifier to manage volume)
  • Software = Volume control but loss of Audio Quality
I would like to use the Software option but I don’t want to lost quality.
Maybe the loss is only when the volume is lower than 100%?
Thanks for your support!
Cheers
Hope someone can help me, I share a couple of screenshots describing the two possible configurations.
For me it’s not really clear what I2S dac do.
