Ahhhh.
O.K. sounds interesting.
I give it a try in just this moment ![]()
Keep you posted.
Ralf
Ahhhh.
Keep you posted.
Ralf
At least the image from Raspi-Imager “works” exactly the same, as the other image.
Because I was curious which version would be installed, I’ve activated system-info plugin.
At least there occurs the first error message I’ve seen yet: “Audio Hardware detection seems to fail” .
rest of status is non-spectacular.
OS info
Version of Volumio: 3.795
Hostname: korellmusik
Kernel: 6.6.62-v8+
Governor: conservative
Uptime: 0 days, 0 Hrs, 9 Minutes, 2 Seconds
Network info
Interface: wlan0
IP Address: 172.23.56.148
MAC Address: 2c:cf:67:60:4c:22
Type: wireless
Speed: nullMb/s
Audio info
Hw audio configured: HDMI 0 Out
Mixer type: None
Number of channels:
Supported sample rate:
Board info
Manufacturer:
Model: Raspberry Pi 5 Model B Rev 1.0 / /
Version: d04170 /
Firmware Version: 2025/02/12 10:51:52 version f788aab6 (release) (embedded)
CPU info
Brand: BCM2712
Speed: 2.4 GHz
Family: unknown
Model: 1
Number of cores: 4
Physical cores: 4
Average load: 2%
Temperature: 46°C
Memory info
Memory: 8147976 Ko
Free: 7225828 Ko
Used: 922148 Ko
Software info
Mpd version: Music Player Daemon 0.23.15 (0.23.15)
Storage info
INTERNAL storage - Size: 4671Mo
Used: 44Mo
Available for storage: 4383Mo (94%)
Audio Hardware is currently NOT installed - use “HDMI 0” - is THIS the error?
I do not have a HDMI device connected…
Regards,
Ralf
Yes, this is exactly what I had done all the time - option 2 with Balena Etcher.
Using Pi-Imager was a (naive) trial to do “something different”.
Yes, it IS.
I definitely do not understand this, but the “bare” approach leads to the described errors.
If I connect a TV to HDMI 0, the player starts to work.
It seems hardware is more “connected” as I thought - it defenitely didn’t come to my mind that I really have to connect an output device.
Sorry for that.
What persists as error: If I click on the skip forward or skip backward button in Web-Interface the skip will be done but the player falls back to “pause” - music stops.
Re-Clicking on “play” sometimes works, sometimes not…
Is this all eventually related to HDMI ??? (sound does NOT appear on TV…) .
Will this may be “healed” if I would supply a DAC?
Really a LOT of thanks to both of you for your great help!
Ralf
BTW: The Pi5 now boots from NVME an image from Volumio’s site ![]()
And: booting is REALLY FAST …
(navigating GUI not that fast - but: HDMI. too ???)
Ralf
Hey @rkorell,
When no DAC is connected, HDMI 0 is the default audio output on the Raspberry Pi 5. Volumio automatically selects it because the Pi 5 does not have an analog audio jack. If no HDMI device is connected, Volumio may not detect an active audio output, leading to playback issues.
Yes, thanks for this.
Any idea for the remaining issues?
Thanks & warm regards,
Ralf
Hey @rkorell,
For the clarity and benefit of the community - can you compile a list please?
Yes for sure.
Regards,
Ralf
Hey @rkorell,
I thought I have explained this; avoiding any confusion how Volumio audio stage works:
Since there is no audio output device like a DAC connected and nothing plugged into the HDMI ports, Volumio has no active audio hardware to control. Functions like playback and track skipping rely on an available audio output, and without one, the player cannot continue playback properly. Connecting a DAC or an HDMI device with audio should resolve this issue.
Yes, understood.
The above errors occured when my TV was connected to HDMI 0 - which currently is defined as Volumio output…
Dear @nerd ,
I’m really happy to announce that the described residual errors are definitely correlated to HDMI.
Today an additional HiFiBerry DAC arrived and it simply works.
So finally thanks a LOT for your patience and your guidance.
Highly appreciated.
Sincerely,
Ralf
yeah if there wasn’t a word for patience yet, it would be nerd. ![]()
