Radio playback interrupts after 10-15 minutes
Dear all,
i am running the latest Volumio version on a Raspberry Pi 3 model B. Audio is directly plugged into the Raspberry.
When playing radio, after 10-15 minutes playback is interrupted. If I increase volume by about 20 units, music plays again, then I lower it back to 14, then it works again for around 15 minutes.
I could find similar, but not the same issues on the forum and on the web, but not suggestions helpded here.
Logs before playback is interrupted:
logs.volumio.org/volumio/rbbMcT7.html
Logs after playback is interrupted:
logs.volumio.org/volumio/DFRbLdG.html
I hope someone has any ideas what I can do.
Thanks a lot for your support
Mike
confirm on radio paradise flac
I can confirm this as will. No yt Song played to its end, stream of radio stops working on most streams.
Any idea?
Happens since release end of 2018.
BTW…two other thread repotimg same
