Radio Paradise Plug In
I have been experiencing some drop out’s and various issues with this plug in installed on volumio system version 2.452 the AAC 320kbps works fine but if i choose to play the flac feed this reboots my pi :open_mouth:
I have uninstalled and reinstalled the plug in but the same thing happens have restarted the pi and router in case the issue was network based
LMS feeds have had there issue’s the last week also but are currently working i am wondering if the problems may have broken the plug in’ yet the other feeds from it work fine at the moment anyone else having the same or similar issue’s ?
Same problem here, Flac causes a reboot.
PI 3B+, USB dac, volumio 2.452
Yes, there is a problem here (Sparky, Volumio 2.411). Can you contact the plugin author?
Sep 11 14:48:04 volumiokitchen volumio[9009]: info: [1536677284719] [RadioParadise] getStream started with url http://api.radioparadise.com/api/get_block?bitrate=4&info=true Sep 11 14:48:05 volumiokitchen volumio[9009]: info: [1536677285058] [RadioParadise] Failed to query radio paradise api, status code: 301 Sep 11 14:48:05 volumiokitchen volumio[9009]: |||||||||||||||||||||||| WARNING: FATAL ERROR ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| Sep 11 14:48:05 volumiokitchen volumio[9009]: ReferenceError: station is not defined Sep 11 14:48:05 volumiokitchen volumio[9009]: at ClientRequest.http.get (/data/plugins/music_service/radio_paradise/index.js:396:26) Sep 11 14:48:05 volumiokitchen volumio[9009]: at Object.onceWrapper (events.js:315:30) Sep 11 14:48:05 volumiokitchen volumio[9009]: at emitOne (events.js:116:13) Sep 11 14:48:05 volumiokitchen volumio[9009]: at ClientRequest.emit (events.js:211:7) Sep 11 14:48:05 volumiokitchen volumio[9009]: at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:551:21) Sep 11 14:48:05 volumiokitchen volumio[9009]: at HTTPParser.parserOnHeadersComplete (_http_common.js:115:23) Sep 11 14:48:05 volumiokitchen volumio[9009]: at Socket.socketOnData (_http_client.js:440:20) Sep 11 14:48:05 volumiokitchen volumio[9009]: at emitOne (events.js:116:13) Sep 11 14:48:05 volumiokitchen volumio[9009]: at Socket.emit (events.js:211:7) Sep 11 14:48:05 volumiokitchen volumio[9009]: at addChunk (_stream_readable.js:263:12) Sep 11 14:48:05 volumiokitchen volumio[9009]: at readableAddChunk (_stream_readable.js:250:11) Sep 11 14:48:05 volumiokitchen volumio[9009]: at Socket.Readable.push (_stream_readable.js:208:10) Sep 11 14:48:05 volumiokitchen volumio[9009]: at TCP.onread (net.js:607:20) Sep 11 14:48:05 volumiokitchen volumio[9009]: ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| Sep 11 14:48:06 volumiokitchen sudo[9400]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl --since=2018-09-11 14:47 Sep 11 14:48:06 volumiokitchen sudo[9400]: pam_unix(sudo:session): session opened for user root by (uid=0) Sep 11 14:48:06 volumiokitchen sudo[9400]: pam_unix(sudo:session): session closed for user root Sep 11 14:48:06 volumiokitchen volumio-remote-updater[462]: [2018-09-11 14:48:06] [error] handle_read_frame error: websocketpp.transport:7 (End of File) Sep 11 14:48:06 volumiokitchen volumio-remote-updater[462]: [2018-09-11 14:48:06] [disconnect] Disconnect close local:[1006,End of File] remote:[1006] Sep 11 14:48:06 volumiokitchen systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE Sep 11 14:48:06 volumiokitchen systemd[1]: Unit volumio.service entered failed state.
I have sent the author a tweet and alerted him to the problem :wink:
radio-paradise-t9886-60.html#p53149
Looks like they have taken down the http api - set it to https and all is good :slight_smile:
Locked to avoid duplication and for clarity … please see plugin thread for the current state of play here :slight_smile:
