Volumio does not show radio logos. Am I forgetting some configuration?
thanks
Are you referring to the pre-configured Radio Stations in Volumio or ones that you have added to “My Web Radios” ?
the stations that I added to the my web radios folder.
For what hardware do you have the issue? Is it a Primo/Rivo?
You need to ssh into volumio, then navigate to the favourites folder: cd /data/favourites/
then edit the my-web-radio-file: nano my-web-radio and add the album art and icon details [e.g. “albumart”:"albumart file,“icon”:“icon file”] be careful, the syntax is important here - then save the edited file. Make sure that you take a backup of your sd card before you start!
Rivo!
I once had missing pictures when I had the volumio device connected to the internet via lan, but my smartphone had logged in via the volumio hotspot. When the smartphone went back to the web ui via the intranet, the pictures were there again.
Before you start hacking the system, create a support ticket since you have support included with the Rivo.
