Queue stops playing after one track
I use a RPi4 with the latest edition of Volumio to a Schiit Modi 3+ and now a SMSL SU1. A few weeks ago I was listening to tracks that I have in an attached HD to a USB port in the RPi and added tracks from Qobuz to the Queue. I have done this many times in the past. After plying the tracks from the HD it just stopped. I have tried many times to play from the queue and I can never get past plying more than 2 tracks, usually only 1. Even when I 'Maually advance" or go back to the queue to select another track everything just stops. No advance, no replay. This first happened a month or so ago. The Modi was working fine when I tested it using the CD player attached via Coaxial. I was using the RPi attached via USB and thought that maybe the problem. I switched to Toslink and that worked OK but the only one track per play problem as detailed above persisted. I have since obtained a SMSL DAC and the same problem.
This is definately not a DAC problem. I did upgrade Volumio to the lastest vesion That did no good. I looked at various settings and fine nothing. I can only play one tack at a time clear the queue and select something else. Playing from the HD as many tacks as I like.
as Premium user you are entitled of dedicated support service
Please raise a ticket HERE
we will be happy to assist you!
Davide
VOLUMIO TECH SUPPORT
