Question for Michelangelo
Michelangelo – Please bear with me…
I have a question about the Current Version of Volumio available at the Google PlayStore for Android 5/5.1 and later (which appears to be version 2.651/2.652). Are you the person to contact for this???
I have several RPi’s and I2s type DACs that I set up earlier this year and that play music via WiFi from USB Flash Drives that I control via Nexus 7 (2012 and 2013) Android Tablets. When I set them up back in April or May (I think), the Google PlayStore version was 2.2 or 2.3). I installed and Via the Setup Gui I give them unique names so that they don’t step on each other and all was well, since I had music playing on both systems!
I was playing music on one of the systems and about 2 weeks ago, I tried to set up a 3rd RPi/I2s combo with another Nexus Tablet (Volumio 2.651/2.652) and had problems because the Tablet or the system became unresponsive. So, I was forced to do a RESET thru SETTINGs which should have deleted/uninstalled Volumio. When I powered the Tablet back up it appeared that some of Volumio was still present (WiFi on the 3rd Tablet showed Volumio was not active but present, the APP was not present)???
So, this time I did a HARD RESET back to FACTORY SETTINGs. Powered the 3rd Tablet up and it still had Volumio under WiFi Settings (No APP present).
Is this normal or some sort of aberation???
Michaelangelo — Please ignore or delete this post. It has finally dawned on me what “VOLUMIO WAS DESIGNED TO RUN HEADLESS” actually means.
I thought it required a dedicated display/control device.
Thanks!!
