Qobuz won't launch
I have managed to add Qobuz to the UI but it won’t launch. It tries, but the load bar gets 95% of the way then stalls. I am probably doing something wrong but not sure what to try next. I did upload the latest update before I started this process.
Many thanks for you help.
Carl
Carl, very hard to understand what you’re trying to accomplish.
Are you using QOBUZ with MyVolumio? If yes, let us know what goes wrong (also via customer service), and we’ll help you.
Otherwise let us know what you’re doing, but every other method is not directly supported by us
