Hi, I’m experiencing the same problem with Qobuz on Volumio Primo HIFI. Of course, with this device I don’t want to install different OS/SW. I guess we will get a solution by Volumio with one of the next updates…
@volumio is there any planned actions on this issue?
I’ve experienced that several times.
If I repeat the aborted track, the error no longer occurs. Yes, it’s true, it’s often inappropriate …
Dear Matteo,
are you in Qobuz trial period?
Can you please send me a log link to techsupport at volumio dot org?
To save log:
Go to IPofVOLUMIO/dev (i.e. 192.168.2.211/dev)–>send log–>copy html link to clipboard and send it to me
Thanks!
Davide
VOLUMIO TECH SUPPORT
Done. Many thanks.
Look at:
Don’t want to be a buzz kill but I’m currently running on the v3.758 of Volumio and this issue is still very present. Is it infixable or it is just that nobody cares?
Version 3.758 is a beta test release, the latest stable and official is 3.757.
BTW, to investigate your issue further, please raise a ticket HERE, and we will get back to you as soon as possible.
Best,
Davide
