python getQueue doesn't receive
I’m trying to get the queue via the websocket in python.
getstate and everything else works perfectly, but i get nothing back from getQueue.
here is the part of the code:
def on_push_state(*args): print args socketIO.emit('getQueue', on_push_state)
in the log file i see:
[1510764504430] ---------------------------- Client requests Volumio queue 2017-11-15T16:48:24.441Z - info: [1510764504439] InterfaceWebUI::pushQueue 2017-11-15T16:48:24.519Z - info: [1510764504507] ------------------------------ 120ms
so i guess that the request works, but there appears to be no answer.
any guesses what the problem is?
thanks a lot.
You need to listen to the
pushQueue
event
thank you soooo much!!!
Have you maybe figured out how to add files to the queue via socketio in python? I just cannot seem to get it working.
