OK Update at last
1st Power supply was DOA, replacement arrived today.
Setup system again with screen attached. Re-Flashed and Powered up.
No colored squares indicating power issues, no lighting bolts or messages about low power (we had the lighting bolt and a warning about low power with the previous power supply)
Boot sequence shows its 5 Phases, thne message about extending filesystem. Finally a filesystem display before the Volumio splash screen and the the login prompt.
Using Ethernet cable between laptop and Pi can connect to volumio.local in firefox.
Walk through initial setup just choosing next, leaving all defaults intact. Do not try and connect to WiFi
Access Dev screen and enable SSH.
Check SSH access is working ok.
Connect to volumio WiFI hotspot. PC connects but cannot connect to volumio.local if the ethernet cable is disconnected. Tried ipconfig /flushdns still no access cant ping volumio.local.
Re-Connect Ethernet cable and access is restored.
Powered down Pi from volumio webpage.
Wait 5 Mins, can only see red light on Pi showing no disk access. Power on Pi , wait till I see splash screen then get login prompt.
System is then as all other previous times. No Webaccess, no SSH access, can connect to hotspot but makes no difference. Can ping volumio.local but only via ethernet.
Use USB keyboard and log on
ip addr shows IP address for ETH0 is what I see if I ping -a volumio.local on the laptop.
I can produce a logfile with journalctl -b. After transferring this back to the laptop, notepad++ says is now only 13000 lines long
looking at it with my untrained eye there seams to be a lot of things repeated after the second power on. Below is what appears to be the repeated lines. I can email the whole log if it will help. I’ve tried attaching it but every time and no matter what name I try I just get The Extension is not allowed.
Nov 03 15:11:27 volumio volumio[5417]: info: -------------------------------------------
Nov 03 15:11:27 volumio volumio[5417]: info: ----- Volumio2 ----
Nov 03 15:11:27 volumio volumio[5417]: info: ----- System startup ----
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin music_service/airplay_emulation. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin music_service/mpd. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin music_service/webradio. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin music_service/example_plugin. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin music_service/last_100. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin music_service/upnp_browser. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin audio_interface/upnp. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin audio_interface/alsa_controller. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin miscellanea/alarm-clock. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin miscellanea/albumart. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin miscellanea/appearance. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin miscellanea/wizard. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin miscellanea/my_music. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin user_interface/websocket. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin user_interface/mpdemulation. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin user_interface/rest_api. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/updater_comm. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/network. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/networkfs. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/services. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/system. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/i2s_dacs. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/volumiodiscovery. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Found new core plugin system_controller/volumio_command_line_client. Adding it
Nov 03 15:11:27 volumio volumio[5417]: info: Plugin folders cleanup
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning into folder /volumio/app/plugins/
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning category audio_interface
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning category miscellanea
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning category music_service
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning category plugins.json
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning category system_controller
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning category user_interface
Nov 03 15:11:27 volumio volumio[5417]: info: Scanning into folder /data/plugins/
Nov 03 15:11:27 volumio volumio[5417]: info: Plugin folders cleanup completed
Nov 03 15:11:27 volumio volumio[5417]: info: ----- Core plugins startup ----
Nov 03 15:11:27 volumio volumio[5417]: info: Loading plugins from folder /volumio/app/plugins/
Nov 03 15:11:27 volumio volumio[5417]: info: Adding plugin upnp to MyMusic Plugins
Nov 03 15:11:27 volumio volumio[5417]: info: Adding plugin airplay_emulation to MyMusic Plugins
Nov 03 15:11:27 volumio volumio[5417]: info: Adding plugin upnp_browser to MyMusic Plugins
Nov 03 15:11:27 volumio volumio[5417]: info: Loading plugins from folder /data/plugins/
Nov 03 15:11:27 volumio volumio[5417]: info: Loading plugin “system”…
Nov 03 15:11:27 volumio volumio[5417]: No id defined. Creating one
Nov 03 15:11:27 volumio volumio[5417]: info: Loading plugin “appearance”…
Nov 03 15:11:28 volumio volumio[5417]: info: Loading plugin “network”…
Nov 03 15:11:28 volumio volumio[5417]: info: Loading plugin “services”…
Nov 03 15:11:28 volumio volumio[5417]: info: Loading plugin “alsa_controller”…
Nov 03 15:11:29 volumio volumio[5417]: info: CoreCommandRouter::volumioUpdateVolumeSettings
Nov 03 15:11:29 volumio volumio[5417]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
Nov 03 15:11:29 volumio volumio[5417]: info: Found match in Cards Database: setting mixer PCM for card Audio Jack
Nov 03 15:11:29 volumio volumio[5417]: info: Loading plugin “wizard”…
Nov 03 15:11:29 volumio volumio[5417]: info: Loading plugin “volumio_command_line_client”…
Nov 03 15:11:29 volumio volumio[5417]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Nov 03 15:11:29 volumio volumio[5417]: info: Loading plugin “upnp”…
Nov 03 15:11:29 volumio volumio[5417]: info: [1541257889209] Starting Upmpd Daemon
Nov 03 15:11:29 volumio volumio[5417]: info: CoreCommandRouter::executeOnPlugin: system , registerCallback
Nov 03 15:11:29 volumio volumio[5417]: info: Loading plugin “my_music”…
Nov 03 15:11:29 volumio volumio[5417]: info: Loading plugin “mpd”…
Nov 03 15:11:29 volumio volumio[5417]: info: Loading plugin “upnp_browser”…
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “networkfs”…
Nov 03 15:11:30 volumio volumio[5417]: info: CoreCommandRouter::executeOnPlugin: system , registerCallback
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “alarm-clock”…
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “airplay_emulation”…
Nov 03 15:11:30 volumio volumio[5417]: info: Starting Shairport Sync
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “last_100”…
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “webradio”…
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “i2s_dacs”…
Nov 03 15:11:30 volumio volumio[5417]: info: I2S DAC not set, start Auto-detection
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “volumiodiscovery”…
Nov 03 15:11:30 volumio volumio[5417]: *** WARNING *** The program ‘node’ uses the Apple Bonjour compatibility layer of Avahi.
Nov 03 15:11:30 volumio node[5417]: *** WARNING *** The program ‘node’ uses the Apple Bonjour compatibility layer of Avahi.
Nov 03 15:11:30 volumio node[5417]: *** WARNING *** Please fix your application to use the native API of Avahi!
Nov 03 15:11:30 volumio node[5417]: *** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=node
Nov 03 15:11:30 volumio node[5417]: *** WARNING *** The program ‘node’ called ‘DNSServiceRegister()’ which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Nov 03 15:11:30 volumio node[5417]: *** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister
Nov 03 15:11:30 volumio volumio[5417]: *** WARNING *** Please fix your application to use the native API of Avahi!
Nov 03 15:11:30 volumio volumio[5417]: *** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=node
Nov 03 15:11:30 volumio volumio[5417]: *** WARNING *** The program ‘node’ called ‘DNSServiceRegister()’ which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Nov 03 15:11:30 volumio volumio[5417]: *** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister
Nov 03 15:11:30 volumio volumio[5417]: info: Applying required configuration parameters for plugin volumiodiscovery
Nov 03 15:11:30 volumio volumio[5417]: Discovery: StartAdv! undefined
Nov 03 15:11:30 volumio volumio[5417]: Discovery: Started advertising… undefined - undefined
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “albumart”…
Nov 03 15:11:30 volumio volumio[5417]: info: Plugin example_plugin is not enabled
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “updater_comm”…
Nov 03 15:11:30 volumio volumio[5417]: info: Plugin mpdemulation is not enabled
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “rest_api”…
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugin “websocket”…
Nov 03 15:11:30 volumio volumio[5417]: info: ___________ START PLUGINS ___________
Nov 03 15:11:30 volumio volumio[5417]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Nov 03 15:11:30 volumio volumio[5417]: info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
Nov 03 15:11:30 volumio volumio[5417]: info: [1541257890788] CoreMusicLibrary::Adding element Media Servers
Nov 03 15:11:30 volumio volumio[5417]: info: [1541257890817] CoreMusicLibrary::Adding element Last_100
Nov 03 15:11:30 volumio volumio[5417]: info: [1541257890820] CoreMusicLibrary::Adding element Webradio
Nov 03 15:11:30 volumio volumio[5417]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Nov 03 15:11:30 volumio volumio[5417]: info: -------------------------------------------
Nov 03 15:11:30 volumio volumio[5417]: info: ----- MyVolumio plugins startup ----
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugins from folder /myvolumio/plugins
Nov 03 15:11:30 volumio volumio[5417]: info: Loading plugins from folder /data/myvolumio/plugins
Nov 03 15:11:30 volumio volumio[5417]: info: Loading i18n strings for locale undefined
Nov 03 15:11:30 volumio volumio[5417]: /volumio/node_modules/fs-extra/node_modules/jsonfile/index.js:73
Nov 03 15:11:30 volumio volumio[5417]: throw err
Nov 03 15:11:30 volumio volumio[5417]: ^
Nov 03 15:11:30 volumio volumio[5417]: Error: /volumio/app/i18n/strings_undefined.json: ENOENT: no such file or directory, open ‘/volumio/app/i18n/strings_undefined.json’
Nov 03 15:11:30 volumio volumio[5417]: at Object.fs.openSync (fs.js:646:18)
Nov 03 15:11:30 volumio volumio[5417]: at Object.fs.readFileSync (fs.js:551:33)
Nov 03 15:11:30 volumio volumio[5417]: at Object.readFileSync (/volumio/node_modules/fs-extra/node_modules/jsonfile/index.js:67:22)
Nov 03 15:11:30 volumio volumio[5417]: at CoreCommandRouter.loadI18nStrings (/volumio/app/index.js:1580:25)
Nov 03 15:11:30 volumio volumio[5417]: at new CoreCommandRouter (/volumio/app/index.js:64:10)
Nov 03 15:11:30 volumio volumio[5417]: at Object. (/volumio/index.js:35:21)
Nov 03 15:11:30 volumio volumio[5417]: at Module._compile (module.js:652:30)
Nov 03 15:11:30 volumio volumio[5417]: at Object.Module._extensions…js (module.js:663:10)
Nov 03 15:11:30 volumio volumio[5417]: at Module.load (module.js:565:32)
Nov 03 15:11:30 volumio volumio[5417]: at tryModuleLoad (module.js:505:12)
Nov 03 15:11:30 volumio volumio[5417]: at Function.Module._load (module.js:497:3)
Nov 03 15:11:30 volumio volumio[5417]: at Function.Module.runMain (module.js:693:10)
Nov 03 15:11:30 volumio volumio[5417]: at startup (bootstrap_node.js:188:16)
Nov 03 15:11:30 volumio volumio[5417]: at bootstrap_node.js:609:3
Nov 03 15:11:30 volumio systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Nov 03 15:11:30 volumio systemd[1]: Unit volumio.service entered failed state.
Nov 03 15:11:30 volumio systemd[1]: Starting dynamicswap service…
Nov 03 15:11:30 volumio systemd[1]: Started dynamicswap service.
Nov 03 15:11:30 volumio volumio-remote-updater[642]: [2018-11-03 15:11:30] [info] asio async_connect error: system:111 (Connection refused)
Nov 03 15:11:30 volumio volumio-remote-updater[642]: [2018-11-03 15:11:30] [info] Error getting remote endpoint: system:107 (Transport endpoint is not connected)
Nov 03 15:11:30 volumio volumio-remote-updater[642]: [2018-11-03 15:11:30] [error] handle_connect error: Underlying Transport Error
Nov 03 15:11:31 volumio systemd[1]: volumio.service holdoff time over, scheduling restart.
Nov 03 15:11:31 volumio systemd[1]: Starting dynamicswap service…
Nov 03 15:11:31 volumio systemd[1]: Started dynamicswap service.
Nov 03 15:11:31 volumio systemd[1]: Stopping Volumio Backend Module…
Nov 03 15:11:31 volumio systemd[1]: Starting Volumio Backend Module…
Nov 03 15:11:31 volumio systemd[1]: Started Volumio Backend Module.
