I am using volumio-2.344-2017-12-16-odroidc2.img on a new Odroid C2 and have a problem after the initial setup screens. I presume one of the config files is not setup correctly
The following extract from the logs keeps repeating
Sep 27 20:21:04 volumio volumio[4133]: info: -------------------------------------------
Sep 27 20:21:04 volumio volumio[4133]: info: ----- Volumio2 ----
Sep 27 20:21:04 volumio volumio[4133]: info: ----- System startup ----
Sep 27 20:21:04 volumio volumio[4133]: info: Plugin folders cleanup
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning into folder /volumio/app/plugins/
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning category audio_interface
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning category miscellanea
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning category music_service
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning category plugins.json
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning category system_controller
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning category user_interface
Sep 27 20:21:04 volumio volumio[4133]: info: Scanning into folder /data/plugins/
Sep 27 20:21:04 volumio volumio[4133]: info: Plugin folders cleanup completed
Sep 27 20:21:04 volumio volumio[4133]: info: Loading plugins from folder /volumio/app/plugins/
Sep 27 20:21:04 volumio volumio[4133]: info: Loading plugins from folder /data/plugins/
Sep 27 20:21:04 volumio volumio[4133]: info: Loading plugin "system"...
Sep 27 20:21:04 volumio volumio[4133]: info: Loading plugin "appearance"...
Sep 27 20:21:05 volumio volumio-remote-updater[457]: [2018-09-27 20:21:05] [connect] Successful connection
Sep 27 20:21:05 volumio volumio[4133]: info: Loading plugin "network"...
Sep 27 20:21:05 volumio volumio[4133]: info: Loading plugin "services"...
Sep 27 20:21:05 volumio volumio[4133]: info: Loading plugin "alsa_controller"...
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "wizard"...
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "volumio_command_line_client"...
Sep 27 20:21:06 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "upnp"...
Sep 27 20:21:06 volumio volumio[4133]: info: [1538079666073] Starting Upmpd Daemon
Sep 27 20:21:06 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: system , registerCallback
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "mpd"...
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "upnp_browser"...
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "networkfs"...
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "alarm-clock"...
Sep 27 20:21:06 volumio volumio[4133]: info: Loading plugin "airplay_emulation"...
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667001] Starting Shairport Sync
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "last_100"...
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "webradio"...
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "i2s_dacs"...
Sep 27 20:21:07 volumio volumio[4133]: info: I2S DAC not set, start Auto-detection
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "volumiodiscovery"...
Sep 27 20:21:07 volumio volumio[4133]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Sep 27 20:21:07 volumio node[4133]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Sep 27 20:21:07 volumio node[4133]: *** WARNING *** Please fix your application to use the native API of Avahi!
Sep 27 20:21:07 volumio node[4133]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Sep 27 20:21:07 volumio node[4133]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Sep 27 20:21:07 volumio node[4133]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Sep 27 20:21:07 volumio volumio[4133]: *** WARNING *** Please fix your application to use the native API of Avahi!
Sep 27 20:21:07 volumio volumio[4133]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Sep 27 20:21:07 volumio volumio[4133]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Sep 27 20:21:07 volumio volumio[4133]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Sep 27 20:21:07 volumio volumio[4133]: info: Applying required configuration parameters for plugin volumiodiscovery
Sep 27 20:21:07 volumio volumio[4133]: Discovery: StartAdv! undefined
Sep 27 20:21:07 volumio volumio[4133]: Discovery: Started advertising... Volumio - undefined
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: system , registerCallback
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "albumart"...
Sep 27 20:21:07 volumio volumio[4133]: info: Plugin example_plugin is not enabled
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "updater_comm"...
Sep 27 20:21:07 volumio volumio[4133]: info: Plugin mpdemulation is not enabled
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "rest_api"...
Sep 27 20:21:07 volumio volumio[4133]: info: Loading plugin "websocket"...
Sep 27 20:21:07 volumio volumio[4133]: info: ___________ START PLUGINS ___________
Sep 27 20:21:07 volumio volumio[4133]: info: PLUGIN START: appearance
Sep 27 20:21:07 volumio volumio[4133]: info: PLUGIN START: wizard
Sep 27 20:21:07 volumio volumio[4133]: info: PLUGIN START: upnp_browser
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667562] CoreMusicLibrary::Adding element Media Servers
Sep 27 20:21:07 volumio volumio[4133]: info: PLUGIN START: last_100
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667582] CoreMusicLibrary::Adding element Last_100
Sep 27 20:21:07 volumio volumio[4133]: info: PLUGIN START: webradio
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667587] CoreMusicLibrary::Adding element Webradio
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Sep 27 20:21:07 volumio volumio[4133]: info: Loading i18n strings for locale en
Sep 27 20:21:07 volumio volumio[4133]: Updating browse sources language
Sep 27 20:21:07 volumio volumio[4133]: Cannot find translation for sourceMedia Servers
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::initPlayerControls
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getAlsaCards
Sep 27 20:21:07 volumio volumio[4133]: info: BOOT COMPLETED
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::Close All Modals sent
Sep 27 20:21:07 volumio volumio[4133]: Express server listening on port 3000
Sep 27 20:21:07 volumio kernel: [aml-i2s-dai]i2s dma ffffff800048e000,phy addr 1611005952,mode 0,ch 2
Sep 27 20:21:07 volumio volumio[4133]: Volumio Calling Home
Sep 27 20:21:07 volumio kernel: ----aml_hw_iec958_init,runtime->rate=44100,sample_rate=5--
Sep 27 20:21:07 volumio kernel: aml_set_spdif_clk rate
Sep 27 20:21:07 volumio kernel: divider=22,frac=13030400,SDMval=2364
Sep 27 20:21:07 volumio kernel: set normal 512 fs /4 fs
Sep 27 20:21:07 volumio kernel: iec958 mode PCM16
Sep 27 20:21:07 volumio kernel: IEC958 16bit
Sep 27 20:21:07 volumio kernel: hdmitx: audio: aout notify rate 44100
Sep 27 20:21:07 volumio kernel: hdmitx: audio: aout notify size 16
Sep 27 20:21:07 volumio kernel: 958 with i2s
Sep 27 20:21:07 volumio kernel: aiu i2s playback enable
Sep 27 20:21:07 volumio kernel: audio_hw_958_enable 1
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667787] CoreStateMachine::resetVolumioState
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667788] CoreStateMachine::getcurrentVolume
Sep 27 20:21:07 volumio volumio[4133]: info: CoreCommandRouter::volumioRetrievevolume
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667804] CoreStateMachine::updateTrackBlock
Sep 27 20:21:07 volumio volumio[4133]: info: [1538079667806] CorePlayQueue::getTrackBlock
Sep 27 20:21:07 volumio volumio[4133]: error: Cannot read config.txt file: Error: ENOENT: no such file or directory, open '/boot/config.txt'
Sep 27 20:21:07 volumio volumio[4133]: info: Cannot read play queue from file
Sep 27 20:21:08 volumio volumio[4133]: info: Setting Device type: Odroid-C2
Sep 27 20:21:08 volumio volumio[4133]: info: MPD running with PID541 ,establishing connection
Sep 27 20:21:08 volumio sudo[4186]: pam_unix(sudo:auth): conversation failed
Sep 27 20:21:08 volumio sudo[4186]: pam_unix(sudo:auth): auth could not identify password for [volumio]
Sep 27 20:21:08 volumio volumio[4133]: events.js:160
Sep 27 20:21:08 volumio volumio[4133]: throw er; // Unhandled 'error' event
Sep 27 20:21:08 volumio volumio[4133]: ^
Sep 27 20:21:08 volumio volumio[4133]: Error: connect ENETUNREACH fd3d:ff8:e477::b2a:6544 - Local (:::0)
Sep 27 20:21:08 volumio volumio[4133]: at Object.exports._errnoException (util.js:1018:11)
Sep 27 20:21:08 volumio volumio[4133]: at exports._exceptionWithHostPort (util.js:1041:20)
Sep 27 20:21:08 volumio volumio[4133]: at connect (net.js:880:16)
Sep 27 20:21:08 volumio volumio[4133]: at net.js:969:9
Sep 27 20:21:08 volumio volumio[4133]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
Sep 27 20:21:08 volumio volumio[4133]: at process._tickCallback (internal/process/next_tick.js:104:9)
Sep 27 20:21:08 volumio systemd[1]: volumio.service: main process exited, code=exited, status=1/FAILURE
Sep 27 20:21:08 volumio volumio-remote-updater[457]: [2018-09-27 20:21:08] [info] asio async_read_at_least error: system:104 (Connection reset by peer)
Sep 27 20:21:08 volumio volumio-remote-updater[457]: [2018-09-27 20:21:08] [error] handle_read_http_response error: websocketpp.transport:2 (Underlying Transport Error)
Sep 27 20:21:08 volumio volumio-remote-updater[457]: [2018-09-27 20:21:08] [info] Error getting remote endpoint: system:107 (Transport endpoint is not connected)
Sep 27 20:21:08 volumio systemd[1]: Unit volumio.service entered failed state.
Sep 27 20:21:08 volumio kernel: aiu i2s playback disable
Sep 27 20:21:08 volumio kernel: audio_hw_958_enable 0
Sep 27 20:21:08 volumio systemd[1]: Starting dynamicswap service...
Sep 27 20:21:08 volumio systemd[1]: Started dynamicswap service.
Sep 27 20:21:08 volumio systemd[1]: volumio.service holdoff time over, scheduling restart.
Sep 27 20:21:08 volumio systemd[1]: Stopping Volumio Backend Module...
Sep 27 20:21:08 volumio systemd[1]: Starting Volumio Backend Module...
Sep 27 20:21:08 volumio systemd[1]: Started Volumio Backend Module.
Thanks.
