You don’t need to install MPD on Windows. MPD is not a separate program — it’s built into Volumio. Your Windows machine / NAS just shares the files; Volumio’s internal MPD engine reads them over the network. You never touch MPD directly. The GitHub repo is for the developers, not for end users.
On your CIFS setting:
You’re already using vers=2.0 , which is exactly what Volumio’s own documentation recommends as the safe default. Keep it as-is.
On the Nova NAS issue you reported:
You already reported the bug with network drive mapping (syntax errors, settings not applying) in the Nova thread. Your issue with the second drive not appearing under Browse may or may not be related to Nova specifically. The quickest way to tell: switch to Manifest (Settings → System → UI Theme → Manifest → Save). If it works under Manifest, it’s Nova; if it doesn’t, the problem is deeper (mount or scan).
Tip: There’s a quirk where the first “Save” click is ignored. Click Save while keeping Nova selected first, then switch to Manifest and Save again.
On the library size (~700,000 tracks):
MPD can handle that many files, but:
- The first scan will be very slow — potentially many hours over a network share. That’s normal. Subsequent scans are faster.
- Non-audio files can cause MPD to stall or abort mid-scan. ISOs, video files, and other non-audio files don’t just slow things down — they can break the scan entirely. At your library size, excluding them isn’t optional.
The fix — .mpdignore files on your Windows share:
The filename must be exactly:
.mpdignore
- It starts with a dot (that’s part of the name, not an extension).
- It has no extension — not
.mpdignore.txt , not .mpdignore.notepad , just .mpdignore .
To create it correctly on Windows:
- In File Explorer, go to View → Show → File name extensions (toggle it on).
- Right-click → New → Text Document .
- Rename it to
.mpdignore . Windows will warn “If you change the file name extension, the file might become unusable” → click Yes .
- Verify in the filename column that it says
.mpdignore and not .mpdignore.txt .
What to write inside (open in Notepad):
Option A — skip the entire folder (if it’s purely junk):
Option B — skip specific file types (if the folder also contains music):
*.iso
*.img
*.zip
*.rar
*.7z
*.tar
*.gz
*.bz2
*.mp4
*.mkv
*.avi
*.mov
*.wmv
*.flv
*.webm
*.m4v
Example with your folder structure:
Music\
Rock\
Jazz\
ISOs\ ← put .mpdignore here with just *
Videos\ ← put .mpdignore here with just *
On the Rivoplus hardware:
It has 2 GB RAM and 16 GB eMMC. For 700k tracks it won’t crash, but if it starts swapping the scan will crawl. The .mpdignore files will help here too — fewer files to scan means less memory pressure.
TL;DR:
- No MPD install — it’s already in Volumio
- Keep
vers=2.0 , it’s correct
- Switch to Manifest as a diagnostic for the Nova issue you reported
- Put
.mpdignore files in the junk folders on your Windows share
- First scan will take a long time — be patient
