Problem RPI 3 B+ and Volumio, no access after reboot
I was using a RPI 3 B with volumio and a DigiOne card without any problem.
I just bought a RPI 3 B+, with the same DigiOne card and impossible to use Volumio.
After flashing I have access to the web interface or SSH, but as soon as I declare the sound output with the DigiOne, I no longer have access to Volumio by http and SSH…
I use the latest version of Volumio.
Any ideas?
Thank you:)
Odd one. Can you check via your router that the IP address of the RPi is actually what you think it is?
Hello chsims1,
Yes it is a good address, I have a IP scanner…
I have reflashed several times, I have good access to the Volumio settings, but after rebooting more access…
With RPI 3 version B, I had no problem…
Thank you:)
There seems to be some sort of issue. I did a fresh Volumio install on my DIgione/RPI3b+ which was using Dietpi/Roon before without issue. After setup with NAS network access to 44.1/16 FLAC files, selecting I2S/Allo Digione for audio hardware and rebooting, am unable to play music. I can select a first song, tell it to play, song play timer runs but no sync lite on coax connected DAC. If I stop song, timer stops but pause symbol is not replaced by start symbol, can delete queue but cannot add music/resume 1st song
Yes Dietpi works very well with a RPI 3 B+
I don’t understand why no one reported the problem with Volumio…
