Problem about error Failed to open "Alsa
I am using volumio ver2.348.
An error Error. Failed to open “Alsa” [Alsa]; Failed to open ALSA device “hw:1,0”: No such file or directory.’ just popped up when i tried to play a music
Im using sparky+piano2.1 and a flash drive containing music file!
Thanks!
PLZ Can someone help?
any help plz?
go back to setting no dac -> Head Jack -> Reboot. Try to play Working? Now select your DAC save it. -> Reboot.
Does it work now?
I have tried that method before but it did not work for me :frowning:
i could play the music when i turned off the dac option but after rebooting and select my dac again it did not work again :frowning:
If you have access to the command line, can you post the result of ‘aplay -l’?
im so sorry to tell that i dont know how to access to the command line :frowning:
i can only access to the volumio /boot/config
Is it still ok?
Go to playback settings -> enable i2s dacs -> select piano 2.1.
Click save , reboot.
Does it play now?
no it does not work :frowning:
