Plugins gone!
using an Allo DigiOne Signature and controlling via iPad with Volumio app, all working fine until today. I went to use Tidal and the icon is missing from the browse menu. I went to the plugins settings menu and both the search and installed plugins tabs are empty.
Cheers
Mark
It’s OK, I found the issue. It seems it doesn’t work with a static IP address. I switched back to Automatic IP and all is well again.
