In scraping mode, research find anything good. Seems not to be the same research as on youtube, and I canât fin d anything good. Only youtube channel and no titles. WeirdâŠ
In google API mode -> Go to verification URL, I enter the code, but in the end I have an error message
Actually I didnât scroll down enoughâŠSo, I just saw âYoutube Channelâ and âYoutube playlistâ. The videos are in the third part and works nice. Is there a way to switch âYoutube videosâ on the top of page ? I tried in the plugin setup but nothing concluantâŠ
I donât know, I followed the âtutoâ and it seems to be the sameâŠ
Under âTest Usersâ, click the â+ Add Usersâ button. Then enter the e-mail address which you will use to access your YouTube account.
See if you can successfully enter the Code afterwards (you will get a âApp not verifiedâ warning - this is normal. Just click âAdvancedâ and âProceed toâŠâ).
For 3/4 problem, you need to update your MPD as stated in the first post of this thread. Or use Volumio 3.x beta.
@patrickkfkan : Iâve just added the test user, and it works nice, I have a : âAccess granted - Volumio has read-only accessto your Youtube Accountâ under Volumio !!
Hi @patrickkfkan,
Everything work perfectly on volumio 3 beta with Youtube API (following your last procedure). Thank you very much for this awesome job !
Damien
I just tested this new plugin and apart from that I can see that there has gone a lot of effort into it, it fails for me just like the precursor.
Client ID and Secret given, it states Access granted but fails to show anything. That is: Google Developer Console shows API access errors and within the UI its either No results or loads infinitely.
That is with the current Volumio version 2.861.
P.s. Scraping method works but that does not give me access to my private playlists.
Iâve now done the whole API process again creating a new project and noticed that at step 7.4 when adding my email as a test user, it states that my email would not be eligible but added it anyway.
Gosh, it works! I needed to disable / re-enable the plugin for the device dialog to pop up again. âUpdateâ or switch to âScrapingâ was not enough. It still stated âAccess grantedâ.
What a charm! Thank you!
P.s. The whole system directly crashed with an
> ssh volumio
___
/\_ \ __
__ __ ___\//\ \ __ __ ___ ___ /\_\ ___
/\ \/\ \ / __`\\ \ \ /\ \/\ \ /' __` __`\/\ \ / __`\
\ \ \_/ |/\ \L\ \\_\ \_\ \ \_\ \/\ \/\ \/\ \ \ \/\ \L\ \
\ \___/ \ \____//\____\\ \____/\ \_\ \_\ \_\ \_\ \____/
\/__/ \/___/ \/____/ \/___/ \/_/\/_/\/_/\/_/\/___/
Free Audiophile Linux Music Player - Version 2.0
C 2015 Michelangelo Guarise - Volumio Team - Volumio.org
permitted by applicable law.
-bash: /etc/profile: Input/output error
-bash: /home/volumio/.bash_profile: Input/output error
but I canât imagine that to be related to the plugin. It never ends ⊠*sigh*
Well ⊠thatâs mostly the case but for now, after hard off/on, it works again. At the moment, nothing particular severe jumps to my eyes.
Unfortunately, since Volumio is configured to save system logs in RAM only, I donât have the logs from earlier but Iâm a bit reluctant to enable that on a potentially dying sd-card âŠ
Hi to all,
I have a nanoPc and volumioBuster x86 latest version 3.036, and when I try to install YouTube2 plugin, it hang on
$ sudo volumio plugin install
"This command will install the plugin on your device
to be more presice: 3.036 is not supported either, it was a pre-release meant to help some NUC users for a specific purpose.
We will announce the beta phase in the next few days, and start with updated versions for PI, Tinkerboard and x86 (x86-64 architecture, so 64-bit only).
