@ dvo
confiremd on 3.10 running the first version of youtube plugin. when you make a playlist i wound play
sorry for the late reaction going to update now
(CONFIREMD FIX) really sweet NICE
great DAY"S and this is really a nice Christmus Gift
@ dvo
back online
morning, here not
09.29
Did you follow these steps to obtain the Client ID and Secret?
Yes, after installing YouTube 2 I am using the old API. When that didnât work, I made a new one, but it still doesnât work.
it works for me i think you are doing things rong but what we cant see. maby send logs ore printscreen on how you are making the keyâs (Wiping out the keyâs afcourse)
@Michal_Muszynski it works tested it many times now all should work wellâŚ
So i think that something is not going right. api worked the first time i used it after update
tested it and worked ok⌠so if your Credentials arenât right ⌠check itâŚ@ google
I know what I did wrong:
For OAuth 2.0 Client IDs - Application Type must be - TV and Limited Input
Thanks for the tips
your welcome
Now there is another problem, the volumio has a problem with tracks longer than 4 minutes. Playback is interrupted and the next track in the list follows.
it sounds like the 3/4 cut off of songsâŚ
i would propose a mpd upgrade :
Exactly as you write, but when I restart the song, sometimes it works properly, sometimes it doesnât. Overall itâs great that this plug works because for me it was one of the most convenient. Thank you very much
did you upgrade the mpd already or not? btw @patrickkfkan did all the great work i help only debugging and testing⌠but already went true the most of the problems âŚ
I already said this in my first post. So did you update your MPD as @dvo suggested?
thanks guys for ur great work. i will give it a try over Christmas break and will let u know if i figure out somethingâŚ
Updated with the following additions:
Cache settings: you can now specify the cache size (in terms of number of entries it can hold) and expiry time (per entry in seconds).
Autoplay: when a YouTube track has finished playing and there are no further tracks in the queue, the plugin will start playing the âUp Nextâ video like you would see on YouTube. Autoplay is disabled by default - you can enable it in the plugin settings.
An autoplayed track is displayed as such in the queue, and replaced by the next autoplay track when playback of the current one finishes. As long as there are no further tracks in the queue and the plugin is able to obtain the âUp Nextâ video, autoplay will continue indefinitely. The Autoplay feature is marked experimental because Iâm not sure how robust the code is in terms of manipulating the queue this way while not messing up Volumioâs state machine. It seems to work well in my case, but more tests needed.
Also note that YouTube can be quirky about âUp Nextâ videos. Even on the YouTube site, you may encounter repetitive âUp Nextâ videos. There is nothing that can be done about thisâŚjust something to be aware of. EDIT: The number of repetitions encountered for some videos is just way higher than what you would normally get on YouTube. I need to look further into thisâŚ
Visit the Github repo for instructions to update the plugin.
Did all the new-installation. It worked out really well and itâs pretty idiot-proof. Thanks a lot for the effort!
Updating and testing
Installed volumio-2.861-2020-12-22-pi.img, Updated the MPD, all working like a charm
really thx
greats all, have a nice christmus
is it possible somehow to add the history of the youtube?
