I tested the youtube connection with chrome browser on pc. I think there is only a problem playing a live stream (radio channel) It buffers the stream 10 seconds and after the buffer is played the stream stops.
Live streams probably wonât work, because it uses a different streaming protocol (HLS / DASH) which MPD doesnât support. I havenât come across a MPD-style headless player that is compatible with such streams, unfortunately.
permitted by applicable law.
Welcome to Volumio for Raspberry Pi (5.4.59-v7l+ armv7l)
volumio@volumio1:~$ mkdir ytcr-plugin
volumio@volumio1:~$ cd ytcr-plugin
volumio@volumio1:~/ytcr-plugin$ git clone https://github.com/patrickkfkan/volumio-ytcr.git
Cloning into âvolumio-ytcrââŠ
remote: Enumerating objects: 1787, done.
remote: Counting objects: 100% (1787/1787), done.
remote: Compressing objects: 100% (1443/1443), done.
remote: Total 1787 (delta 269), reused 1782 (delta 264), pack-reused 0
Receiving objects: 100% (1787/1787), 2.26 MiB | 2.35 MiB/s, done.
Resolving deltas: 100% (269/269), done.
volumio@volumio1:~/ytcr-plugin$ cd volumio-ytcr
volumio@volumio1:~/ytcr-plugin/volumio-ytcr$ volumio plugin install
This command will install the plugin on your device
Compressing the plugin
No modules found, running ânpm installâ
/bin/sh: 1: /usr/local/bin/npm: not found
Error installing node modules: Error: Command failed: /usr/local/bin/npm install
/bin/mv: cannot stat â*.zipâ: No such file or directory
child_process.js:650
throw err;
Error: Command failed: /bin/mv .zip /tmp/plugins/ytcr.zip
/bin/mv: cannot stat '.zipâ: No such file or directory
at checkExecSyncError (child_process.js:607:13)
at execSync (child_process.js:647:13)
at install (/volumio/pluginhelper.js:689:9)
at Object.<anonymous> (/volumio/pluginhelper.js:751:9)
at Module._compile (module.js:653:30)
at Object.Module._extensions..js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
at Function.Module.runMain (module.js:694:10)
I have written too quickly that morning !
I have done anothers tests, the playlist works !! and the automatic next song too !! I am so sorry for the misunderstanding !!
So, i have been in error because of anothers bugs :
This morning, seeing someone had that issue, i have moved the volumio timeline bar to the end for see if it will go to the next song without really listen to the music (low volume, my children was near watching TV ) . I see now that moving the timeline bar has no effect on the playing song, and at the end it come back at 0s and stop moving.it is why i throught it wasnât working.
Also, When i deplace the youtube timeline, it has no effect on the playing song in volumino. After, when the youtube timline arrive at the end, it come at the time where the song is playing on volumino.
The youtube song are not playing up to the end. The last approximatively 30sec are not playing and it pass to the next song.
I have to test more to see exactly what the matter, but i have seen after playing few youtube songs volumio come back to the initial volumio playlist. I hear the initial playlist but it is the youtube picture on the player. I have to test more, that problem seems absent if the volumio playlist is empty.
When you say âdeplace the timelineâ, did you mean seeking? You also said you didnât update your MPD, which is why seeking doesnât work and the songs got cut off early (I assume you are running Volumio 2.x and not the beta 3.x).
sorry itâs casting it to 2 devices ⊠thatâs why it has a echo lol
playing goes well , but add to queue doesnât showup in queue,
but if i press next it will play the nextâŠit will play the whole playlist
You are adding on the mobile app, right? When you add a video to the queue it should show up as the last item in the queue. The app will add it first, then notify the plugin that the queue has been updated. At least thatâs my case - Android, YouTube version 16.14.34
