Here the entire sequence:
1 - stop web radio
2 - start Spotify, Play
3 - does not work
4 - Close Spotify
5 - disable and re-enable the VolSpot plugin
6 - Start Spotify
7 - It works normally
Starting Live Log...
wlan0: CTRL-EVENT-DISCONNECTED bssid=3c:b7:4b:3a:4d:50 reason=7 locally_generated=1
wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
wlan0: Trying to associate with SSID 'Mapear 2.4 GHz'
wlan0: Associated with 3c:b7:4b:3a:4d:50
wlan0: WPA: Key negotiation completed with 3c:b7:4b:3a:4d:50 [PTK=CCMP GTK=TKIP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 3c:b7:4b:3a:4d:50 completed [id=0 id_str=]
wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=AR
info: Listing playlists
info: CorePlayQueue::getQueue
info: CoreCommandRouter::volumioPause
info: CoreStateMachine::pause
info: CoreStateMachine::stPlaybackTimer
info: CoreStateMachine::servicePause
info: CoreCommandRouter::servicePause
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info: CoreStateMachine::syncState stateService pause
info: CoreStateMachine::syncState currentStatus pause
info:
info: ControllerMpd::pushState
info: Received update from a service different from the one supposed to be playing music. Skipping notification.Current radio_paradise Received mpd
info: ------------------------------ 42ms
info: ------------------------------ 21ms
[Vollibrespot] : Connecting to AP "guc3-accesspoint-b-wdpz.ap.spotify.com:443"
[Vollibrespot] : Authenticated as "danielfelix" !
[Vollibrespot] : Setting up new mixer: card:hw:2 mixer:Digital index:0
[Vollibrespot] : Alsa Mixer info min: 0 (MilliBel(-9999999)[dB]) -- max: 207 (MilliBel(0)[dB]) HW: true
[Vollibrespot] : Using alsa sink
[Vollibrespot] : Metadata pipe established
[Vollibrespot] : Event: Volume { volume_to_mixer: 13107 }
[Vollibrespot] : Country: "AR"
[SpotifyConnect] 20
[SpotifyConnect] Volume: Spotify:20 Volumio: 20
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: SessionActive { became_active_at: 1596579087456 }
[Vollibrespot] : SessionActive!
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 181526245921843748686528109162483859992, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 181526245921843748686528109162483859992, audio_type: Track } }
[SpotifyConnect] A connect session has begun
[SpotifyConnect] Device palyback is active!
[SpotifyConnect] Currently active: radio_paradise
[SpotifyConnect] Stopping currently active service
info: CoreCommandRouter::volumioStop
info: CoreStateMachine::stop
UNSET VOLATILE
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreStateMachine::serviceStop
info: CoreCommandRouter::serviceStop
info: ControllerMpd::stop
info:
info: CoreStateMachine::syncState stateService stop
info: CoreStateMachine::syncState currentStatus stop
info: No code
[SpotifyConnect] Vollibrespot Active
[SpotifyConnect] Setting Volatile state to Volspotconnect2
info: Received update from a service different from the one supposed to be playing music. Skipping notification.Current radio_paradise Received volspotconnect2
[SpotifyConnect] Currently active: undefined
[SpotifyConnect] Pushing new state :: true
info:
info: ------------------------------ 81ms
info: ------------------------------ 45ms
[Vollibrespot] : No autoplay_uri found
[Vollibrespot] : AutoplayError: MercuryError
[Vollibrespot] : Event: GotToken { token: Token { access_token: "BQCPebyLQxpHQ6SibGmaNKDiwBDTmCdsIi6V19xUOtaas1KZ-9j7ww8TSReKmsqPf5K8Mlc6UFJytaLBQX5hCy0fW3nPkhExOQvqxm1WYNRNA0cyIuhNzvGNS-bGkXfcLXwRcavd0cJthT-fIq78Tr_Ke1Xnp0wranDm-QM", expires_in: 3600, token_type: "Bearer", scope: ["streaming", "user-read-playback-state", "user-modify-playback-state", "user-read-currently-playing", "user-read-private"] } }
[SpotifyConnect] BQCPebyLQxpHQ6SibGmaNKDiwBDTmCdsIi6V19xUOtaas1KZ-9j7ww8TSReKmsqPf5K8Mlc6UFJytaLBQX5hCy0fW3nPkhExOQvqxm1WYNRNA0cyIuhNzvGNS-bGkXfcLXwRcavd0cJthT-fIq78Tr_Ke1Xnp0wranDm-QM
[Vollibrespot] : Loading with Spotify URI
[SpotifyConnect] Setting VLS device_id: c6e56cf6b68c07041768b06e2f29a439e7724b0e
[Vollibrespot] : (409640 ms) loaded
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 181526245921843748686528109162483859992, audio_type: Track } }
[SpotifyConnect] Device palyback is inactive
[SpotifyConnect] Device Session is_active: true
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 181526245921843748686528109162483859992, audio_type: Track }, track_id: SpotifyId { id: 145388607699475846999067032348438672553, audio_type: Track } }
[Vollibrespot] : (206800 ms) loaded
[Vollibrespot] : Alsa error PCM open ALSA function 'snd_pcm_open' failed with error 'EBUSY: Device or resource busy'
[Vollibrespot] : Could not start audio: Alsa error: PCM open failed
thread '' panicked at 'called `Option::unwrap()` on a `None` value', /build/cache/git/checkouts/librespot-6f197fd632ef9380/659de68/playback/src/audio_backend/alsa.rs:128:19
stack backtrace:
0: 0xad1828 - backtrace::backtrace::libunwind::trace::h100c6c70e4af496c
at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.40/src/backtrace/libunwind.rs:88
1: 0xad1828 - backtrace::backtrace::trace_unsynchronized::hf78ddc194bf45009
at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.40/src/backtrace/mod.rs:66
2: 0xad1828 - std::sys_common::backtrace::_print_fmt::h967a212a8894e4a4
at src/libstd/sys_common/backtrace.rs:77
3: 0xad1828 - ::fmt::h5fe383ce2118859a
at src/libstd/sys_common/backtrace.rs:59
4: 0xaed03c - core::fmt::write::h937f59172f6eeeaf
at src/libcore/fmt/mod.rs:1052
5: 0xacb6ec - std::io::Write::write_fmt::hc70e2634948b89c8
at src/libstd/io/mod.rs:1426
6: 0xad3cf0 - std::sys_common::backtrace::_print::hbfc81757b29a60f4
at src/libstd/sys_common/backtrace.rs:62
7: 0xad3cf0 - std::sys_common::backtrace::print::h8bc349c117633211
at src/libstd/sys_common/backtrace.rs:49
8: 0xad3cf0 - std::panicking::default_hook::{{closure}}::h82c47dcbb8503118
at src/libstd/panicking.rs:204
9: 0xad3964 - std::panicking::default_hook::hc04800be16711189
at src/libstd/panicking.rs:224
10: 0xad43a0 - std::panicking::rust_panic_with_hook::h2413ff75e44cd581
at src/libstd/panicking.rs:472
11: 0xad3fb4 - rust_begin_unwind
at src/libstd/panicking.rs:380
12: 0xaeaaa8 - core::panicking::panic_fmt::h2c56481ca2ee7c2f
at src/libcore/panicking.rs:85
13: 0xaeaa04 - core::panicking::panic::h858859fb9e6c3f07
at src/libcore/panicking.rs:52
14: 0x69bf40 - ::write::h72619216e3588ead
15: 0x676e38 - ::poll::h8c3aa347eb5050fe
16: 0x578b0c - futures::task_impl::std::set::h959dffae037fa8a9
17: 0x573048 - futures::task_impl::Spawn::poll_future_notify::h3ba01a9dfc1d022c
18: 0x57f6d4 - std::sys_common::backtrace::__rust_begin_short_backtrace::h53457226459490b1
19: 0x590e08 - std::panicking::try::do_call::h3a2683b9b75c33db
20: 0xad85f8 - __rust_maybe_catch_panic
at src/libpanic_unwind/lib.rs:86
21: 0x591140 - core::ops::function::FnOnce::call_once{{vtable.shim}}::he4fab1c16e3e7b3d
22: 0xac4488 - as core::ops::function::FnOnce>::call_once::h0eb934bdc214e7b7
at /rustc/b8cedc00407a4c56a3bda1ed605c6fc166655447/src/liballoc/boxed.rs:1015
23: 0xad78f8 - as core::ops::function::FnOnce>::call_once::h4eeee9ec160fd74c
24: 0xad78f8 - std::sys_common::thread::start_thread::hd648575d6de17db0
at src/libstd/sys_common/thread.rs:13
25: 0xad78f8 - std::sys::unix::thread::Thread::new::thread_start::hc1903f20153f9439
at src/libstd/sys/unix/thread.rs:80
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 145388607699475846999067032348438672553, audio_type: Track } }
[SpotifyConnect] Apenas Floto
[SpotifyConnect] Pushing metadata
info: CoreCommandRouter::executeOnPlugin: my_volumio , detectVolumioHardware
info: Could not detect Volumio Device: Error: Command failed: aplay -l | grep es90x8q2m-dac-dai-0
[SpotifyConnect] Relinquishing Volumio State
UNSET VOLATILE
[SpotifyConnect] unSetVolatile called
[SpotifyConnect] Relinquishing Volumio State to another service
[SpotifyConnect] Received stop
[SpotifyConnect] Stopping Vollibrespot daemon
[SpotifyConnect] Closing metadata listener
info: CoreStateMachine::resetVolumioState
info: CoreStateMachine::getcurrentVolume
info: CoreCommandRouter::volumioRetrievevolume
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop volspotconnect2.service
info: Disabling plugin volspotconnect2
info: Done.
Stopping Volspotconnect2 Daemon...
Stopped Volspotconnect2 Daemon.
[SpotifyConnect] Vollibrespot Daemon service stoped!
info: VolumeController:: Volume=20 Mute =false
info: Enabling plugin volspotconnect2
info: Loading plugin "volspotconnect2"...
info: PLUGIN START: volspotconnect2
[SpotifyConnect] Creating VLS config file
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
[SpotifyConnect] Starting metadata listener
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start volspotconnect2.service
Starting Volspotconnect2 Daemon...
Started Volspotconnect2 Daemon.
vollibrespot v0.2.1 1438440 2020-05-15 (librespot 659de68 2020-05-10) -- Built On 2020-05-15
Reading Config from "volspotify.toml"
[Vollibrespot] : Using Alsa backend with device: plughw:Loopback
[SpotifyConnect] Vollibrespot Daemon service started!
e[34m [Metrics] e[39m SpotifyConnect: e[31m 0s 103.86ms e[39m
info: Done.
[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: "No such device" }
[Vollibrespot] : Connecting to AP "guc3-accesspoint-b-qsg4.ap.spotify.com:443"
[SpotifyConnect] 20
[Vollibrespot] : Event: SessionActive { became_active_at: 1596579216043 }
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 145388607699475846999067032348438672553, audio_type: Track } }
UNSET VOLATILE
[Vollibrespot] : Event: GotToken { token: Token { access_token: "BQB0Apw4ZCdb8LaOXCHJrav_-Y_aSqDpTn552JY1kNq18_SsaIwe9hjxaDd3kLjPL1riJ6eGL_cym-p1hrXtdj-S-NA0QenKeu6gpzvaz-McmRrJG0hQoASJAPqo3T4fH0wYCxz9xwayhTCMSPL4VSgGtG1klVacVemxRCw", expires_in: 3600, token_type: "Bearer", scope: ["streaming", "user-read-playback-state", "user-modify-playback-state", "user-read-currently-playing", "user-read-private"] } }
[SpotifyConnect] BQB0Apw4ZCdb8LaOXCHJrav_-Y_aSqDpTn552JY1kNq18_SsaIwe9hjxaDd3kLjPL1riJ6eGL_cym-p1hrXtdj-S-NA0QenKeu6gpzvaz-McmRrJG0hQoASJAPqo3T4fH0wYCxz9xwayhTCMSPL4VSgGtG1klVacVemxRCw
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 145388607699475846999067032348438672553, audio_type: Track } }
[Vollibrespot] : Resolving uri "spotify:station:user:spotify:playlist:37i9dQZEVXcMU5Gn41qZ9Y"
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 145388607699475846999067032348438672553, audio_type: Track }, track_id: SpotifyId { id: 22747588139279626277758005283872091704, audio_type: Track } }
[Vollibrespot] : Resolved 50 tracks from <"spotify:station:user:spotify:playlist:37i9dQZEVXcMU5Gn41qZ9Y">
[Vollibrespot] : (186466 ms) loaded
[SpotifyConnect] Mrs. Cold
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 22747588139279626277758005283872091704, audio_type: Track } }
[Vollibrespot] : Event: SinkActive
[SpotifyConnect] Sink acquired
CIFS VFS: Server 192.168.0.18 has not responded in 180 seconds. Reconnecting...
