Plugin Touchscreen: cover art size
Hello!
I use the TouchscreeN Pluging only to see the Volumio screen on my tv, so everyone in the house knows what’s on play.
I removed the pointer and the sleep feature, and it is beautiful but… do you know if (and how) is possible to increase the size of the cover ? On a 7in monitor the cover is perfect, but on a tv i have half of the screen not used (i think it is because of the ratio) and bigger cover art could be better.
…maybe it is possible to descrease the plugin resolution? In this way everything on screen should appear bigger… but i don’t know if it works this way.
Thank you!
Luca
+1 same idea, nice to have a bigger cover on Tv out :unamused:
